1. Re: Setting gaps to specific values
rob day Jun 13, 2014 11:51 AM (in response to isips)You can check Use Spacing with a value in the Align panel, select the objects you want to space and click Distribute Spacing
2. Re: Setting gaps to specific values
isips Jun 13, 2014 3:28 PM (in response to rob day)Ok, yes, thank you Rob, that worked wonderfully. Do you know how it decides it anchoring point when it distributes? Right now it just moves the lower object down and the more right object to the right, while the objects in the upper left always stay put.
3. Re: Setting gaps to specific values
P Spier Jun 14, 2014 3:16 AM (in response to isips)What version of ID are you using? I don't believe the ability to select a Key Object was introduced until CS6, or perhaps 5.5.
4. Re: Setting gaps to specific values
isips Jun 16, 2014 8:56 AM (in response to P Spier)I am using the Creative Cloud Version
5. Re: Setting gaps to specific values
P Spier Jun 16, 2014 9:01 AM (in response to isips)After making the selection of objects you want to align, click once more on the Key object (it should get a heavy outline), then use the panel.
6. Re: Setting gaps to specific values
isips Jun 16, 2014 9:54 AM (in response to P Spier)That is great, thank you Peter. That will help me a lot going forward
