We are using RH10 and building nightly with a perl script that calls RH.exe. Recently we noticed the process time went from two hours to six, and the number of files in wghdata in a couple of the projects multiplied and became much, much larger. Many of them ballooned from 30-50kb to 2-2.5mb.
Has anyone else experienced this? Is there anything in the updated .js files in the recent hot fix that might account for this?
It appears to be a setting in the .ssl file, would turning off Mark of the Web have this effect?
All the MOTW does is add a single line to each topic so that will not be the cause.
I haven't seen any other reports of this so it looks like an environment issue. Have you tried publishing to a new location, or the same one if you are willing to trash all existing content?
