Show 4 replies
1. Re: Automatically changing gradient issues....
P Spier Jun 16, 2014 3:15 PM (in response to Real Estate Designer)Are you using a defined gradient swatch with the same name, but different definitions in the two files?
2. Re: Automatically changing gradient issues....
Real Estate Designer Jun 16, 2014 3:31 PM (in response to P Spier)That is possible. What is the best way to bring in a vector image with a gradient into a file that already has a gradient and not have the gradients get messed up? I really don’t even know if I am describing this correctly… thanks for your help!
3. Re: Automatically changing gradient issues....
P Spier Jun 16, 2014 3:35 PM (in response to Real Estate Designer)Any time you bring content from one file to another and it has an attribute like a swatch or style that shares a name with the destination document the destination definition will be used. Best not to use things like Gradient Swatch 1 for a name.
4. Re: Automatically changing gradient issues....
Real Estate Designer Jun 16, 2014 3:41 PM (in response to P Spier)This is exactly the answer I needed. I knew it was something simple! Thank you, problem solved!
