quote:... yes, but you always could do that - at least since Captivate 1, or earlier. Just open the waveform in Edit mode, position the playhead, and record.
Can you edit an existing recording, by recording a new phrase and insert it or replace a section of an existing audio file?
quote:... again, yes you can, but again, you can do that in prior versions. Go to the Audio menu and select Edit Timing.
Can you change the timing for a recording that was previously spread over 3 slides, so that it now is spread over 4 slides?
