Show 2 replies
1. Re: Supported Word Versions
Peter Grainge Jun 17, 2014 6:24 AM (in response to brianc@ionics.ca)This is a Printed Documentation problem. I have moved it from HTML 5 Layouts. Please see the Sticky Topic on which forum to post in.
There isn't a patch but if you right click the layout and select Properties, you should be able to generate. You will not be able to import from Word as there is no workaround for that.
2. Re: Supported Word Versions
Willam van Weelden Jun 17, 2014 6:43 AM (in response to Peter Grainge)As Peter said, there is no official. workaround. But you may want to check out the following thread: http://forums.adobe.com/message/5368354#5368354 Proceed with caution.
Kind regards,
Willam
