WebHelp sits on a server and can be accessed from there by
the application.
By pushed, do you mean installed? If the user nonetheless
will always have access to the server to obtain the help, then is
that an option.
If not, you can either install a CHM locally or now you can
install the webhelp locally. Previously running webhelp locally
brought up a yellow information bar unless various IE settings were
changed. Not really what you wanted for an end user. Now you can
create the webhelp with the Mark of the Web added and it will run
locally. I believe links to PDFs may not work so check that out if
relevant.
I am guessing that for your developers, it means they only
have to change the path to the help so it could be quite a saving.
Otherwise the calls to a CHM topic would be different.
