1. Re: coldfusion 11 I've installed it - how do I get to cfadmin?
Carl Von Stetten Jun 17, 2014 1:31 PM (in response to happysailingdude)How about http://127.0.0.1/CFIDE/administrator/index.cfm ?
Did you choose to connect ColdFusion to Apache during the installation? Did you enable the built-in server?
-Carl V.
2. Re: coldfusion 11 I've installed it - how do I get to cfadmin?
happysailingdude Jun 17, 2014 1:43 PM (in response to Carl Von Stetten)Thanks Carl
That's getting closer I think - I got this "Not Found
The requested URL /CFIDE/administrator/index.cfm was not found on this
server." but it looks like a cf generated error rather than the other 2
urls which was chrome's 404 error.
I opted to use the built in cf server during installation - I don't recall
apache coming in to the equation at all. I was running cf 10 and that didnt
involve apache as far as I recall..
Really appreciate your help, thank you.
Anything else I could try?
Thanks.
ᐧ
3. Re: coldfusion 11 I've installed it - how do I get to cfadmin?
BKBK Jun 17, 2014 1:52 PM (in response to happysailingdude)What about just http://127.0.0.1:8500/ ?
It could be that something went wrong with the /CFIDE directory.
4. Re: coldfusion 11 I've installed it - how do I get to cfadmin?
happysailingdude Jun 17, 2014 1:55 PM (in response to happysailingdude)hi Dan - alas that just gives the chrome 404.
However this http://127.0.0.1/ gives "It works!" so something's running..
5. Re: coldfusion 11 I've installed it - how do I get to cfadmin?
BKBK Jun 18, 2014 12:50 AM (in response to happysailingdude)Isn't that Railo? With Coldfusion that URL should show a directory structure.
6. Re: coldfusion 11 I've installed it - how do I get to cfadmin?
happysailingdude Jun 18, 2014 2:05 AM (in response to BKBK)I havent installed ralio
7. Re: coldfusion 11 I've installed it - how do I get to cfadmin?
BKBK Jun 18, 2014 2:35 AM (in response to happysailingdude)Then it must be something else other than your present ColdFusion installation. The words "It works!" ring a bell, but not a ColdFusion one. Certainly, Apache.
I think Carl got it spot on. You seem to be using the Apache web server. Verify this and, if so, either uninstall it or configure it for use with Coldfusion.
8. Re: coldfusion 11 I've installed it - how do I get to cfadmin?
happysailingdude Jun 18, 2014 2:41 AM (in response to BKBK)Thanks chaps I really appreciate you helping with this.
I've just searched for apache on my mac and found this directory
/Applications/ColdFusion10/cfusion/runtime/work/Catalina/localhost/tmp/org/apache
I thought I'd uninstalled cf10 but maybe not and also maybe that's where
the apache thing is coming from.
I've already run the cf10 uninstall once so how do i get rid of this?
Thanks so much for your help. I can code in cf but alas don't know anything
about server admin etc so really appreciate your help. Thank you.
ᐧ
Nick
9. Re: coldfusion 11 I've installed it - how do I get to cfadmin?
Anit Kumar Panda Jun 18, 2014 5:10 AM (in response to happysailingdude)If you select Production profile or Production + Secure profile during installation, by default directory browsing is disabled for ColdFusion directory. You will get the below error message:-
Here are the steps to enable the same:-
- Navigate to C:\ColdFusion11\cfusion\runtime\conf and open the web.xml with notepad.
- Change “false” to “true” in <param-value>false</param-value> (as shown in the screenshot below)
3. Save the file and restart “ColdFusion 11 Application Server” service.
Anit Kumar
