I have a problem regarding applescript and acrobat.
Since there is no acrobat scripting forum, i posted it here.
I have an applescript that runs perfectly with Acrobat pro 10.
But now I want to run it on a computer where Acrobat pro 11 is installed and it makes Acrobat quit on the "insert pages" command.
I installed Acrobat 11 on my mac as well and it has the same behaviour: it quits on the insert pages.
If i use the Acrobat 10, it is still executing correctly...
Is there an issue with this function in javascript too?
Has anyone experienced the same problem or has a solution?
Part of the script below:
tell application "Adobe Acrobat Pro"
set deneerste to open file outputFormaat
set dentweede to open file outputPDF
set afmetingen to media box of page 1 of document 2
set hoogte to (item 2 of afmetingen)
set breedte to (item 3 of afmetingen)
if hoogte < breedte then
set rotation of page 1 of document 2 to 90
end if
repeat oplage times
--This is where Acrobat 11 quits...
insert pages document 1 after -1 from document 2 starting with 1 number of pages 1
end repeat
close document 2 saving no
close document 1 saving yes
end tell
