Set the output format images generated from graphic elements
Jun 19, 2014 Jun 19, 2014
Hello,
When I save as XML, my graphic elements generate image files with several extensions .mif, .jpeg, .gif or others.
Is it possible to force an output format?
Scripting
403
Advisor ,
Yes, there are r/w rules that control the way graphics are exported. In particular, the anchored frame, facet, and convert referenced graphics rules are relevant.
     --Lynne
Thanks for your answer.
I don't know that much about framemaker, how do you declare r/w rules to control graphics export ?
Advisor ,
Jun 20, 2014 Jun 20, 2014
Check the Structured Application Developer's Guide at http://help.adobe.com/en_US/FrameMaker/9.0/StructuredDev/Structure_Dev_Guide.pdf.
     --Lynne
Jun 24, 2014 Jun 24, 2014
Thanks for your help Lynne,
Here is the solution if it can helps, first we have to declare read/write rules file in Application Definitions (Structured Tools > Structured Application Designer).
In this file we can specify what we want like this :
element "graphic" { // markup tag name
  is fm graphic element "Graphic"; // select all graphics framemaker elements named Graphic
  writer anchored frame { // if it is an anchored frame export it
    notation is "CGM"; // with type CGM
    export to file "$(docname).cgm"; // in file with the document name and extension cgm}}
There is much more rules in doc that gave Lynne.
One more thing, the export didn't works for me until I fixed xml parsing errors on my dtd.
Hope it helps.
