I have received this message several times through CFERROR.
The cause of this output exception was that: ClientAbortException: java.net.SocketException: Connection reset by peer: socket write error.
How can I fix this?
This started happening like in your application?
Any change in the server?
What happened?
I migrated to the CF 11, but I saw that the CF 10 have this happen, but do not know how to solve
What is the web server that you are using?
Windows 2008 - IIS 7 + CF 11
I would completely uninstall ColdFusion 10 and delete all system files pertaining to it.
I believe your problem is the same as described in this link.
http://www.jjask.com/360015/connection-reset-socket-write-error-cfcontent-coldfusion
I recommend you check how is being done to build the content. See what can be done to optimize module that uses this service. Reinstall not believe solve because before this error was sent to the server.log and now he shoots at the screen which to me is one of the things that came embedding tomcat in coldfusion. I did not had this problem in applications migrated but I confess that neither uses cfcontent very heavy and only way to load images and download pdfs.
I believe that even if you reinstall this error is inherent to its Application. Review application is something that can solve the problem.
Hope this helps
