1. Re: Why did Adobe release separate CC apps for 2014? Now I have duplicates of everything...
nw42 Jun 23, 2014 5:05 AM (in response to jyaroslow)It's great to have new versions like the 2014 update as separate application!
So we have a smooth transition if bugs or workflow problems occour - if anything goes wrong simply start the old version and wait until the new one get fixed...
2. Re: Why did Adobe release separate CC apps for 2014?
JSS1138 Jun 23, 2014 6:45 AM (in response to jyaroslow)Supposedly, Red Giant released new version compatible with CC 2014 last Thursday.
3. Re: Why did Adobe release separate CC apps for 2014?
Jerry Klaimon Jun 23, 2014 7:39 AM (in response to jyaroslow)Thai Red Giant blog may be of some help
Red Giant - Red Room Blog » We are Ready for Creative Cloud 2014
4. Re: Why did Adobe release separate CC apps for 2014?
jyaroslow Jun 23, 2014 11:31 AM (in response to JSS1138)Yes, I read about that too, but I don't think this is a Red Giant issue per se. I think it's a flawed execution strategy on the part of Adobe. In addition to plugins such as Red Giant not working properly, I also had to reset some settings in PP CC 2014. Why add extra work for the end user? Adobe's previous enhancements in CC releases didn't require all this work on the part of the end user. I'm still looking for a good answer on why they decided to create a separate version for most of their applications.
5. Re: Why did Adobe release separate CC apps for 2014?
nw42 Jun 23, 2014 12:33 PM (in response to jyaroslow)If they release small sub releases you just get an update for the current installation - but if you get a major update like the CC2014 release you get a new install to ensure that your current workflow don't break because of plugin issues and bugs...
That is an important mechanism to protect your working Adobe CC environment and has to be done that way for security reasons.
--> You can import your personal settings via cloud sync to the 2014 version...
6. Re: Why did Adobe release separate CC apps for 2014?
nw42,
Thanks for the explanation and the cloud sync recommendation. I understand the workflow argument very well; however, the irony with that rationale is that by proceeding with a separate app, Adobe did in fact break my workflow. Also from a file management perspective, we now have 2 versions of the same app running in our post facilities, which creates added confusion. The only way I was able to repair these issues for Red Giant users was to uninstall ALL my Red Giant apps and reinstall them with the CC 2014 version checked. Previously, all I had to do to upgrade Red Giant was go to Red Giant Link and run an update--which was much simpler. What changed in this release that required Adobe to change the game on how they released updates and required 3rd party plugins to have to create a new workflow as well? Adobe had significant updates & changes in October 2013 and December 2013, but those didn't require a new app. Why now? Why create more headache for users with multiple plugins, etc?
7. Re: Why did Adobe release separate CC apps for 2014?
nw42 Jun 23, 2014 1:18 PM (in response to jyaroslow)Adobe had significant updates & changes in October 2013 and December 2013, but those didn't require a new app. Why now?
This update caused some major issues in our pipeline and we had to roll back and install previous versions of the apps during a tight deadline to get our deliverables out of the door... So I like the idea of "never touch a running system" and add the new version in parallel instead...
But as you write plugins also have to be considered here... By default the should work in the old version and you should be able to install them on teh new version to check if everything works fine...
If I think about Autodesk software there is the same situaltion: We install the new version 2013...2014...2015 in parallel and then adding all the plugins. If everything works as expected the next to last version can be deinstalled from the system.
So you have a stable sytem and a new system all the time...
--> CC2014 Apps are in approval stage now. We test them with our leads and if there are no show stoppers we set the signal to switch all workstations at once company wide...
8. Re: Why did Adobe release separate CC apps for 2014?
jyaroslow Jun 23, 2014 1:54 PM (in response to nw42)Thanks. I think your approach makes sense. I just feel like Adobe shifted the paradigm on us with this release--when compared to the 2013 CC releases. I thought that once Adobe went to the CC model, there wouldn't be a need to have this testing & cutover period, like we did with when upgrading from CS4 to CS5, or CS5 to CS6. I know now that that is to be expected every year or so--or whenever they have a "major" release. Bummer.
