Hi John,
Let me put it this way.
Developers are developing an application for Windows Vista
platform using Visual Studio 8.
As stated in your mail, I am curious to know how they would
be able to automatically generate the context sensitive help for
HTML Help (do you mean .chm?).
The next is that I have imported a Header file (res.h, for
example) and generated the corresponding Map IDs. Do I need to give
the same header file (res.h) to the developer? If yes, where do
they place it?
I have also generated a chm. Where do they place the same? I
need to know the path.
Next, where else do they need to make changes so as to
integrate the chm with their application?
Last but not the least, as stated by you ,"You will then need
to compile your help project and the RoboHelp_CSH.cpp project.
These two compiled projects (the application and CHM) should then
work together", you mean to say that I copy RoboHelp_CSH.cpp in
thier project. RoboHelp_CSH.cpp is found in my RoboHelp's directory
and not where the help is located.
I did place RoboHelp_CSH.cpp and CHM at the project's
location, however, I did not suceed.
Regards
Shalini
