1. Re: Returning library books early
Frustrated in AZ May 25, 2011 7:47 PM (in response to Annpeece)Your library ebook has a small file attached to it that holds information
from the publisher and the library. If you put your cursor on the ebook's
avatar in ADE Library view, you'll see a small arrow appear. Clicking on
that arrow will drop down a menu, and one of the entries 'should' be 'return
to library' or words to that effect. When you click on that entry, the
ebook will be 'returned' to the library. (What actually happens is that ADE
sends a message to the library and then deletes the ebook.)
Hope this helps!
2. Re: Returning library books early
Annpeece May 26, 2011 4:46 PM (in response to Frustrated in AZ)Appreciate the response but it doesn't work for me.
Assuming you are talking about my desktop (and not a handheld device), I just don't know what you mean by an avatar. I can't find anywhere on the library view screen where the arrow you described appears.
Would you mind trying again?
Thanks so much!
3. Re: Returning library books early
Frustrated in AZ May 27, 2011 9:32 AM (in response to Annpeece)The 'avatar' is the picture of the cover of the book or the line of
description that appears in ADE's Library view. When you put your cursor on
this, a box appears around it, and a little arrow (actually something like
this: > ) appears in the upper left hand corner of the box. when you put
your cursor on this arrow, a note appears that says 'Item Options'. When
you click on the arrow, a drop-down box will appear, and the choices will
include opening the item, deleting the item, item info (publisher rights,
and other stuff) and return item to library if it's a library book. Notice
that ebooks are called 'items'.
Hope this helps!
4. Re: Returning library books early
Annpeece May 27, 2011 9:39 AM (in response to Frustrated in AZ)Thank you- that was helpful!
5. Re: Returning library books early
dendrobia Jun 25, 2014 12:36 PM (in response to Frustrated in AZ)What if there is no Arrow or Little White Triangle (described in another post) on the book thumbnail? when I click on it, only a blue rectangle surrounding the thumbnail and title appears. Working in MacBook Pro (10.6.8) with ADE 2.0
6. Re: Returning library books early
dendrobia Jun 25, 2014 12:49 PM (in response to dendrobia)Just found the answer on my the Overdrive site: on a Mac, in the ADE Library: Control-Click on the book icon in the upper left and the menu for returns and other options appears. For me control-click did not work highlighting the book icon on the right.
