1 Reply Latest reply: Jun 26, 2014 8:32 AM by Carl Von Stetten RSS
    which driver best for DB connection Native driver vs jdbc drivers
    Srinivas VK Community Member
      In ColdFusion we can create DSN in 2 ways. Either we can select the driver for the specific database or we can use the Other as the driver and we can create the DSN by specifying the connection string. Which is the best way in terms of the performance for apps. Any idea.
      Here I am looking to create the DSN to SQL Server 2012 and I have create 2 DSN's, one with SQL Server  driver and one with other and mentioned the connection string.  I don't see any difference as of now. Please advise which one to user.
        • 1. Re: which driver best for DB connection Native driver vs jdbc drivers
          Carl Von Stetten MeganK
          Srinivas,
          The only time I use the "other" driver and a JDBC connection string is when I need to use a feature of the database system that isn't directly supported in the provided driver.  As an example, Microsoft SQL Server's "Always On" feature and spatial/hierarchical data types aren't supported in the provided DataDirect drivers that ship with ColdFusion, but they can be used if you use Microsoft's JDBC driver.
          As to performance, I haven't done testing personally.  I think as long as you are using a JDBC driver, the performance differences should be negligible.  Just avoid ODBC connections when possible, as these are generally slower than JDBC.
          -Carl V.
