LiveCycle Form won't submit in Citrix environment
Avatar
Former Community Member
Hi All,
I have a PDF Form I created in LiveCycle Designer that after being filled out should be able to be submitted as a PDF to a ColdFusion processing page. The form works fine as a stand alone file and in the browswer on a typical desktop computer, but when trying to submit through a Citrix session the form does nothing. In the browser, there is no HTTP request being sent and if the PDF is opened from a saved file and submitted (again in a Citrix session) it prompts to ask if the user wants to allow the request and then after clicking YES it does nothing.
Anybody have any experience or ideas about why this would be a problem?
Avatar
Hey did you happen to figure out your issues with this?  It looks like i am running into the same problem.
Avatar
Level 10
If you press Ctrl + J, there's the JavaScript Debugger that appears, is there any error that is shown in the Console box?
Avatar
Pressing Ctrl + J does not make the debugger appear for me.  I also created another button that shows an alert message once pressed, and that looks to be working.  It is just the HTTP submit.
Avatar
Level 10
To make the debugger appear, you must change settings in Adobe Acrobat Pro.
Open LiveCycle
Open Adobe Acrobat Pro
In Adobe Acrobat pro ► Edit ► Preferences ►JavaScript
►Check: Enable Acrobat Javascript
►Check: Enable JavaScript Debugger after Acrobat is restarted
►Check: Enable interactive console
►Check: Show console on errors and messages
you can also see here how to do it
LiveCycle ES2 * Adobe LiveCycle Designer ES2
