1. Re: Source Settings for BMPCC Crash
Kees filmeditor Jun 26, 2014 11:18 AM (in response to SixTwo Pro)I Had the same problem when trying to edit the source settings when i was using a dvi monitor as reference monitor. But if i use a blackmagic output over sdi there was no problem.
2. Re: Source Settings for BMPCC Crash
Kevin-Monahan Jun 26, 2014 5:01 PM (in response to SixTwo Pro)Hi SixTwo Pro,
See if this post helps solve that: Blackmagic Design is not an option in Adobe Premiere Pro CC : Blackmagic Design
Kevin
3. Re: Source Settings for BMPCC Crash
Kees filmeditor Jun 27, 2014 3:11 AM (in response to Kevin-Monahan)Kevin, you must be very busy; your reply is totally off subject.
4. Re: Source Settings for BMPCC Crash
SixTwo Pro Jun 27, 2014 8:02 AM (in response to Kees filmeditor)Kees, I'm glad I'm not the only one who saw this. I was turning my laptop upside down and reading between the lines to see if there was some secret code Kevin was talking about embedded within the article. Kevin, you posted an article about audio in response to a question purely about video. Shall we try again?
5. Re: Source Settings for BMPCC Crash
Kevin-Monahan Jun 27, 2014 12:11 PM (in response to SixTwo Pro)Hi,
I was pointing out that the BM drivers are not seen by CC 2014 applications, as reported by Peter Garaway in Premiere Pro engineering (second post). Sorry if that was confusing. Can you contact BMD Support and see what they say?
Kevin
