Show 2 replies
1. Re: One to many DataMerge
P Spier Jun 27, 2014 2:56 AM (in response to Sajid Attar)ID's built-in Data Merge is strictly a 1:1 application. You can set up your records with fields for multiple policies and leaves some blank, though, and Data Merge can remove blank lines (which means any white space or punctuation must be part of the data). You might also be able to do this with XML.
2. Re: One to many DataMerge
Sajid Attar Jun 27, 2014 9:20 PM (in response to P Spier)Thanks for the help, I will try this.
