1. Re: CameraRaw is not updated in Photoshop CC and Photoshop CC 2014. Active version is still 8.3, although 8.5 is available. AAM and CC App say everything up-to.date.
Eggi Jun 19, 2014 1:39 PM (in response to Eggi)Solved ! Found another post in this forum that gave me some useful hints. You have to download Camera Raw 8.5 manually.
Download link for Camera Raw 8.5.0.236 for Windows is http://swupdl.adobe.com/updates/oobe/aam20/win/PhotoshopCameraRaw8-8.0/8.5.50/setup.zip
The Installer didn't work, so I only unzipped the file. You can find the Camera Raw plugins in the sub-directories:
32-bit version:
- > payloads/AdobeCameraRaw8.0All-050614141453/Assets1_1.zip
extract file "1003" and rename it to "Camera Raw.8bi"
copy it to c:/Program Files (x86)/Common/Adobe/Plug-ins/CC/File Formats/CameraRaw.8bi (previous CameraRaw is overwritten, you should copy old version to a save place first)
64-bit version:
- > payloads/AdobeCameraRaw8.0All-x64-050614143245/Assets1_1.zip
extract file "1002" and rename it to "Camera Raw.8bi"
copy it to c:/Program Files/Common/Adobe/Plug-ins/CC/File Formats/CameraRaw.8bi (previous CameraRaw is overwritten, you should copy old version to a save place first)
Start Photoshop CC and open a RAW file to be sure it's ok now.
2. Re: CameraRaw is not updated in Photoshop CC and Photoshop CC 2014. Active version is still 8.3, although 8.5 is available. AAM and CC App say everything up-to.date.
PzSniper Jun 20, 2014 9:38 PM (in response to Eggi)WOW that worked flawlessy! Thanx Eggi...
What about AdobeCameraRawProfile8.0All-050614142248? How can we install em same way?
3. Re: CameraRaw is not updated in Photoshop CC and Photoshop CC 2014. Active version is still 8.3, although 8.5 is available. AAM and CC App say everything up-to.date.
Eggi Jun 21, 2014 2:22 AM (in response to PzSniper)Installing the profiles is much more complicated, since they all have non-standard names in Assets1_1.zip. And there a 372 files in the zip file !
The mapping can be found in Install.db (which is a SQLite database) in table InstallFile.
If you are interested in a specific (new) profile you might search it there, rename it and copy it to the appropriate location. Found some more info in a blog, which is about an older version of Camera Raw, but might still be helpful:
http://meefirst.blogspot.nl/2012/07/manually-installing-adobe-camera-raw.html
If you have Lighroom 5.5 installed, you might also copy the profiles from the Lightroom profiles directory to the Photoshop profiles directory (see notes in the above blog).
If you have a Photoshop CS6 installation on the same PC and it has been updated by AAMUpdater, you don't need to take care for CC/CC2014 because they use the same profile directory.
regards
Eggi
4. Re: CameraRaw is not updated in Photoshop CC and Photoshop CC 2014. Active version is still 8.3, although 8.5 is available. AAM and CC App say everything up-to.date.
R_Kelly Jun 21, 2014 3:55 AM (in response to Eggi)You can always just install the 8.5 dng converter, which will install the needed profiles for camera raw 8.5
5. Re: CameraRaw is not updated in Photoshop CC and Photoshop CC 2014. Active version is still 8.3, although 8.5 is available. AAM and CC App say everything up-to.date.
Lynnea1941 Jun 21, 2014 7:18 AM (in response to Eggi)Thanks so much for this information. It solved my problem.
Lynnea
6. Re: CameraRaw is not updated in Photoshop CC and Photoshop CC 2014. Active version is still 8.3, although 8.5 is available. AAM and CC App say everything up-to.date.
Eggi Jun 21, 2014 8:12 AM (in response to R_Kelly)good hint ! that's probably the easiest and quickest way ...
7. Re: CameraRaw is not updated in Photoshop CC and Photoshop CC 2014. Active version is still 8.3, although 8.5 is available. AAM and CC App say everything up-to.date.
KateMann Jun 24, 2014 6:38 PM (in response to Eggi)I just spent hours online with two excellent Adobe employees who finally fixed the problem by switching out the 8di files. It works.
8. Re: CameraRaw is not updated in Photoshop CC and Photoshop CC 2014. Active version is still 8.3, although 8.5 is available. AAM and CC App say everything up-to.date.
colcar Jun 27, 2014 5:10 AM (in response to Eggi)Eggi, you are awesome!
Thank you for putting me out of my misery. I tried installing the 8.5 DNG Converter, but it didn't fix the problem.
Eggi's solution works perfectly.
Thank you!
9. Re: CameraRaw is not updated in Photoshop CC and Photoshop CC 2014. Active version is still 8.3, although 8.5 is available. AAM and CC App say everything up-to.date.
Eggi Aug 3, 2014 10:06 AM (in response to Eggi)The download link for Camera Raw 8.6 for Windows is:
http://swupdl.adobe.com/updates/oobe/aam20/win/PhotoshopCameraRaw8-8.0/8.6.28/setup.zip
