I have Googled and searched this community for an answer for 9 months, and I have found nothing.
I need to update Flash Player on my Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon with 8 GB 1066 MH DDR3 RAM. I'm running OS X version 10.9.3. I am able to download the update, but when I try to open it, I get this:
This continues to happen, even with each further update I attempt. FYI, Flash Player works just fine in my browser (Firefox), but at some point, my Flash Player is going to be so outdated that it won't work. I have no idea how to handle this problem. Any help would be GREATLY appreciated.
There is a lot of different problems with Flash Player install.
To help everyone, please edit your question subject.
Here is a suggestion:
Flash Player installation problem on MacOS X 10.9 .
Here is the way I got a running version with the same OS:
Please, if this is working or failing:
add a message here to help everyone.
I'm not sure what any of the options you listed in answer 1 means, but answer 2's link corrected my issue. I've successfully installed it on my system.
I also cannot find a way to edit the subject of my question. I can edit my reply posts, but not the original for some reason. I'll paste your suggestion here so that it hopefully comes up in Google searches.
You cannot edit a post once someone has replied to it. I have modified the subject for you.
This works!!!! I can't thank you enough! I have been crazy trying to get the proper information to load flash player 14. I had determined to just give up watching any videos. Thank you.
