I have this strange query of queries result that could be a bug in CF11. The result is fine in CF10.
Basically, I have 2 queries, qrA and qrB. I do a join of the two in joinQr, after which I do a query of qrA. Since I didn't alter qrA in any way, I would expect newQrA to give me the same result as qrA. However it only gives me one row ("D"). Now, here's the strange thing: If I start off qrA with the letters in ascending order ["A", "B", "C", "D"], then newQrA gives me the right result.
<cfset qrA = queryNew("")>
<cfset queryAddColumn( qrA, "size", "varchar", [ "D", "A", "B", "C" ] )>
<cfset qrB = queryNew("")>
<cfset queryAddColumn( qrB, "size", "varchar", [ "A" ] )>
<cfset queryAddColumn( qrB, "quantity", "integer", [ 0 ] )>
<cfquery name="joinQr" dbtype="query">
select qrA.*, qrB.quantity
from qrA, qrB
where qrA.size = qrB.size
</cfquery>
<cfquery name="newQrA" dbtype="query">
select *
from qrA
</cfquery>
<cfdump var="#qrA#">
<cfdump var="#qrB#">
<cfdump var="#joinQr#">
<cfdump var="#newQrA#">
it'd help if you showed us what these queries look like, and possibly some sample data.
Sorry, I had trouble inserting the code earlier. It's fixed now.
For your interest, by coincidence, my first test was with
<cfset queryAddColumn( qrA, "size", "varchar", [ "A","B","C","D" ] )>
It turns out that the order "A","B","C","D" works, whereas "D","A","B","C" fails. Quite funny, really.
Thanks for confirming that it's a bug. I will file a bug report. I don't know what changes they made under the hood to QoQ, but to me this is serious because I can no longer trust the result of QoQ. I wouldn't have caught this if a user didn't point out a result that made no sense.
Thanks. In discovering this flaw, you have done the Coldfusion community a big favour.
I have added my vote to your bug report. It reads: "+My vote. Query of Queries is a cornerstone of Coldfusion. This issue is so serious as to raise questions about the reliability of the entire language.".
I made an error when I first tested your code with array variable names instead. However, I have now been able to reproduce your result. It indeed looks like a bug.
