Show 3 replies
1. Re: "Access Denied" opening PDF from network UNC path.
Rave Jun 30, 2014 2:14 PM (in response to Ayenoy)Hi ayenoy,
I am unable to replicate the issue with Reader 11.0.7 at my end.
Rave
2. Re: "Access Denied" opening PDF from network UNC path.
Test Screen Name Jul 1, 2014 2:41 AM (in response to Ayenoy)If it were Unix I would say: make sure that you give Execute permission to each higher level folder. No idea if that is applicable or even meaningful in Windows.
3. Re: "Access Denied" opening PDF from network UNC path.
Kshakti Jul 1, 2014 3:08 AM (in response to Ayenoy)Hi Ayenoy,
Please provide the following information:
1) Adobe Reader version on your machine.
2) OS you are using.
3) Is your machine or the shared drive a part of any special file system like DFS etc.
4) Is the user a normal admin/standard user or a special user with roaming profile and folder redirections?Thanks,
Shakti K
