1. Re: [AI-CS5] Unable to capture panel closed/Hide event .
david_a_clark Sep 6, 2011 3:44 AM (in response to INeedSol)I believe this is a bug in Illustrator CS5. Because panels are only hidden (rather than truly closed) when the user clicks to close them, the close event does not fire. I think this is unique to Illustrator and it should be fixed for CS6.
In the meantime there is this slightly ugly workaround, where you can set up a timer to intermittently poll the visible property of a window, which accurately reflects whether the panel window is visible (unlike the closed property, which as you have noted remains 'false' until Illustrator itself is closing).
<csxs:CSXSWindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:csxs="com.adobe.csxs.core.*" layout="absolute" historyManagementEnabled="false" creationComplete="onCreationComplete()" > <mx:Script> <![CDATA[ protected function onCreationComplete():void { var t:Timer = new Timer(3000); t.addEventListener(TimerEvent.TIMER, onTimerEvent); t.start(); } protected function onTimerEvent(event:TimerEvent):void { trace("visible: " + visible); trace("closed: " + closed); } ]]> </mx:Script> </csxs:CSXSWindowedApplication> -
2. Re: [AI-CS5] Unable to capture panel closed/Hide event .
INeedSol Sep 7, 2011 1:49 AM (in response to david_a_clark)thanks a lot!
3. Re: [AI-CS5] Unable to capture panel closed/Hide event .
Michael Peters Jul 1, 2014 4:52 AM (in response to INeedSol)It seems unbelievable that two versions on in CS6 this was still not fixed and that the visible property was also not updating. Does anyone know if this is now working in CC?
4. Re: [AI-CS5] Unable to capture panel closed/Hide event .
rixter123 Aug 13, 2014 11:18 PM (in response to Michael Peters)Looks like the bug is in CC as well. This is really frustrating. (Tested in the original Photoshop CC. Not sure about CC 2014).
