Guess what -- they came back.
Here's another approach.
By the way, I'm running Windows XP with Office 2003, RH 6
installed.
1. In Windows, go to Start > Settings > Control Panel
> Add or Remove Programs. Ensure that 1-Step RoboPDF does not
appear on the list. If it does, uninstall it.
2. Go to Start > Run > regit. This opens the Registry.
(Disclaimer: You can get into a lot of trouble editing in here.
These steps worked for me on two PCs with no apparent side effects.
Work slowly and think before deleting.)
3. Select Edit > Find. Type in RoboPDF. Check Keys, Values
and Data. Click "Find Next."
4. Delete the entry that contains RoboPDF. Find next (F3) and
repeat. Continue to the utter end.
Sometimes a folder or key will disappear completely. Some
subkeys will revert to (Default) and (value not set), and will
remain. Just continue and be sure you delete only the lines or keys
that contain RoboPDF.
5. Clean up MS Word templates and other Office app toolbars.
In my case, I had to delete all old Normal.dot templates,
even though I had renamed them OLDNormal.dot and saved a revised
global template. If you've never replaced the global template and
saved backups in the Templates folder, you won't have this problem.
a. Launch MS Word and close the new blank document.
b. In the main menu, select Tools > Templates and Add-ins.
c. Click "Organizer" and the Toolbars tab.
The left-hand pane should be labeled Normal.dot. If you see
1-Step RoboPDF listed, select it and click "Delete."
d. Close the Organizer.
e. Right-click the main toolbar and look for 1-Step RoboPDF.
If it's there, select Customize. Highlight it and click Delete.
f. In MS Word, open Normal.dot as a *.dot template, not as
Document1.doc.
g. Repeat steps a through e.
h. Exit Word and Restart the PC.
If the PC has more than one user profile, you should do this
with each profile. You'll see this in C:\Documents and
Settings\Application Data (set folder options to show hidden and
system files). You need admin rights on the PC to do this. Restart
the PC after each profile (okay, maybe I'm superstitious. I have
reason to be.)
If this doesn't work, do it all over again.
Cleaning up the registry might take care of Powerpoint,
Excel, and Outlook, but . . . .
a. launch the application and close the new document.
b. Examine Tools > Add-ins
c. Repeat step e above (even if the toolbar doesn't show at
first, it may still be listed as an add-in or toolbar option).
In my housekeeping frenzy, I also cleaned out all the "Recent
Files" links.
Uninstalling and re-installing RH 6 may not be necessary. If
you do this, don't forget the .dll update.
Last but perhaps not least, Adobe is working on the next
upgrade for release on a date not yet announced. Maybe this problem
will go away.
Harvey
