HI, A couple of days ago facebook & ninemsn (my homepage) starting advising that I didnt have and needed to download adobe flash to view various items.
It hadnt been uinstalled, and this was new.
Since then I have downloaded it and various runtime versions, and the plug-in...and neither have 'stuck'. IN using firefox google or IE...all the same result.
Appreciate some advise to resolve and rationale as to why this popped up
cheers
lethal40
By "ninemsn" you mean http://www.ninemsn.com.au/ ?
If so, it's them doing that. When I go to that website and try to view a video I get
It's usually these kind of manipulation that leads to erroneous messages like you get.
Can you confirm that Flash Player works correctly on your browser: http://helpx.adobe.com/flash-player.html
Is the Shockwave Flash plugin enabled in each browser?
Can you post a screenshot of that information you get: https://forums.adobe.com/thread/1070933
Hi Pat, thanks for the prompt response.
I have searched to enable these and cannot confirm they are in either browser.
In firefox I have ended up with something called 'flash control' 1.0.7
No sign of a plug in for either.
Can you kindly provide some direction around this (I have been out of the it file game for too long)
I have inserted above the sort of thing I am now seeing from ninemsn.
Look forward to your or further advises
regards
lethal40
Hi Pat,
Thanks for your response.
Yes indeed. I refer to ninemsn.com.au.
The display message your see is different to mine, and mine has only just started..
or are you saying i should also see the message you get?
I also clicked on the link to check flash player, and was advised it was not installed or enabled...and to (again) download it....i didnt.
Luv to know what the hec is going on....
Is there an plug in i should enable for firefox, chrome & IE?
Look forward to hearing from you
regards
lethal40
Hi again Pat,
That link to check flash player, seems to have solved my issue. That page also provided detail as to how to enable the plugins, I sought earlier...done and resolved!
Thanks muchly.
I did put shockwave flash and adobe flash player as one and the same...apparently it/they are.
regards
lethal40
