When I click on "File Search" the search box appears, I enter the search criteria and it finds nothing. I have installed a standalone search product in the meantime but it's a real pain to get out of builder, run the search, and then pull up each file to make changes. Any idea what this problem might be?
The results show up in the search panel. That panel may not be obvious. Is there anything in that panel?
The panel shows up it just says "zero matches in working set". Any other ideas?
That sucks. This is what worked for me:
-Selected the project in the navigator
-Clicked on the search menu item and the search dropdown.(same as cntrl-h)
-Entered my search term.
-Put in *.cfc, *.cfm for the file name pattern
-Selected 'Enclosing projects' which is supposed to search the project selected.
-Clicked the search button.
I gave you the initial response above because I didn't notice the search panel the first time I tried it.
You found it! I had always used "Working set" and one or more selected working sets. That doesn't work nor does selected resource. However "Enclosed Projects" and the much wider scope of "Workspace" do work. Thank you!
