my-amf pinging endpoint
Avatar
Level 1
Hi all, I have an app. that uses remoteObjects, I'm building
some logic for the remoteObject handler, and I'm testing the app.
right now and the app is running, and I kill the JRun, and there is
the issue, I want to catch the ('my-amf' pinging endpoint) or is it
some other way to do the checking for JRun server are running
Avatar
Former Community Member
I'm not sure what you're asking if you are asking how you'd
know when the server is down, you could listen for fault events and
eventually when the client cannot contact the server, you'll get a
fault event.
Avatar
Level 1
Hi :)
this is wath I do with the RO
public function loginUser(user:String, pass:String):void {
flexComRO = new RemoteObject();
flexComRO.destination = "FlexComRO";
flexComRO.LoginUser.addEventListener(ResultEvent.RESULT,
loginUserResultHandler);
flexComRO.LoginUser.addEventListener(FaultEvent.FAULT,
faultHandler);
CursorManager.setBusyCursor();
flexComRO.LoginUser(user,pass);
If i have the Flex app running in my browser, and hit the
loginUser function, with the JRun disconected. It hangs on the
'my-amf' pinging endpoint. where sould I put the event listener if
I should catch the event ? Or do I have to create a my own timeout
Avatar
Why are you doing this?
faultHandler);
I think you need the following instead:
flexComRO.addEventListener(ResultEvent.RESULT,
flexComRO.addEventListener(FaultEvent.FAULT, faultHandler);
And when the JRun server is down, you should see a fault
event in your "faultHandler" method (that I assume is already
defined).
Avatar
Level 1
Hi. I have some changes.
/** code snipp
faultHandler);
I'm doing it becouse I call many method's from Java.
I have the flexComRO.addEventListener(FaultEvent.FAULT,
faultHandler); to look for faults like server down -- this is the
one that seems not to work..
And I have
faultHandler); to look for fault's in LoginUser method in Java
Avatar
Hi Cato,
You're syntax is fine and you can listen at the service level
(flexComRO) or the operation level (flexComRO.LoginUser).
What is happening under the covers is that the RemoteObject's
underlying
Producer has ChannelSet. This ChannelSet loops through
pinging each of
its Channels until one responds successfully. If you have
more than one
channel defined for your RemoteObject destination it will
move on to the
next before failing outright.
However, you may also be experiencing a bug where say if the
Channel was
an AMFChannel, it's underlying flash.net.NetConnection may
not be
throwing an error? Or perhaps the bug is that he AMFChannel
is receivng
and error but not correctly dispatching the error?
You could try getting the channelSet off the RemoteObject
instance and
adding an event listener for a "channelFault" type of event.
What version of FDS or LCDS are you using? Could you open the
rpc.swc in
WinZip and look at catalog.xml and let us know what the
version
information says?
Pete
Avatar
Level 1
Hi Pete
I'm using FDS 2.0.1
here is the info on rpc.swc file
<?xml version="1.0" encoding="utf-8" ?>
- <swc xmlns="
http://www.adobe.com/flash/swccatalog/9">
- <versions>
<swc version="1.0" />
<flex version="2.0.1" build="155493" />
</versions>
And I'm only using one channel for all the RemoteObjects.
do you have a sample code for me: "You could try getting the
channelSet off the RemoteObject instance and
adding an event listener for a "channelFault" type of event."
Cato
Avatar
There should be a channelSet propety on
mx.rpc.remoting.RemoteObject. This
channelSet is an instance of mx.messaging.ChannelSet (and it
should contain
an instance of mx.messaging.channels.AMFChannel).
import mx.messaging.ChannelSet;
import mx.messaging.events.ChannelFaultEvent;
private function loginUser(user:String, pass:String):void
var channelSet:ChannelSet = flexComRO.channelSet;
channelSet.addEventListener(ChannelFaultEvent.FAULT,
handleChannelFault);
private function
handleChannelFault(event:ChannelFaultEvent):void
trace(event.toString());
Avatar
Level 1
Hi if i try this it returns a error :
TypeError: Error #1009: Cannot access a property or method of
a null object reference.
Avatar
The null pointer exception is because ChannelSet has not been
initialized by the RemoteObject yet when you try to add a listener
to it. One workaround is that you can manually create your own
ChannelSet and assign it to the RemoteObject, and then add the
listener to the ChannelSet. Something like:
var cs:ChannelSet = new ChannelSet();
cs.addChannel(new RTMPChannel(null, "
http://localhost:2400"));
flexComRO.channelSet = cs;
I just used RTMPChannel with a random url as an example but
you'll use whatever Channel you have with the right url.
