31 Replies Latest reply: Jul 31, 2014 9:12 AM by Kevin Monahan RSS
    Premier Pro 2014 is very sluggish
    SAPOL Community Member
      I installed Premier Pro 2014 last week and since then it's been running very slowly with frequent crashes. I have been using Premier Pro CC on a daily basis since it was first released
      and hardly ever had a problem with it. Very frustrated and disappointed with this latest release - so have now decided to go back to to the more reliable Premier Pro CC.
      I am hoping that this is a teething problem with Premier Pro 2014 - and that soon an update will be released that will make it just as stable as Premier Pro has proven to be.
        • 1. Re: Premier Pro 2014 is very sluggish
          mdsunc30 Community Member
          I've been having lots of crashing with Premiere Pro CC 2014 as well.  It doesn't seem slower on my system, but it crashes several times a day for no apparent reason.
          • 2. Re: Premier Pro 2014 is very sluggish
            Jim Simon CommunityMVP
            [Please post only one thread per issue.  I've deleted the second thread, which had no replies.]
            • 4. Re: Premier Pro 2014 is very sluggish
              Kevin Monahan Adobe Employee
              Hi Mdsunc30,
              Is it possible to get more details about your issue? FAQ: What information should I provide when asking a question on this forum?
              Kevin
              • 5. Re: Premier Pro 2014 is very sluggish
                Indie767 Community Member
                I'm experiencing the same issue. Premiere Pro CC 2014 unexpectedly stops working on my Windows 7 machine. I was running the previous version of Premiere Pro CC with no crash issues.
                • 6. Re: Premier Pro 2014 is very sluggish
                  Hi Kevin,
                  Thank you for your help in advance.  I'm using Premiere Pro 8.0, Mavericks 10.9.3, source footage is AVCHD (it happens at all frame rates), I've been having crashes when rendering, when playing back footage, when exporting...I have Red Giant Color Suite installed.  Computer is brand new Mac Pro 6 Core, AMD D500s, 512 GB SSD internal hard drive, 32 GB RAM, I have a GRAID 6TB Thunderbolt hard drive as well as a couple other USB drives connected, I have a Matrox MX02 mini connected.  When I'm using the hardware acceleration in AME it crashes almost every time i export.  When I use software only it does not crash on export, but it still crashes during rendering, playback, and just while doing normal editing things.  The export crashing happened with premiere 7.2.2 but the other crashing did not happen.  Now that I'm on 8.0 I'm getting crashing all over the place.
                  Mike
                  • 7. Re: Premier Pro 2014 is very sluggish
                    Kevin hi -
                    I am on an iMac - OSX 10.7.5 - 3.4 GHz Intel Core i7 -
                    RAM - 16GB 13333 MHz DDR3
                    Graphics Card - AMD Radeon HD 6970M 2048 MB
                    I have been using Prem Pro CC since it's release - with no problems at all - it is very stable and works very well.
                    BUT -
                    Now I have started a project on Premier Pro 2014 - and it has not been very productive.
                    I have been getting the Beach Ball spinning many times a day - for no apparent reason - so with all the on going crashes and
                    re starts it has been very slow going.
                    I would like to be able to open my current project in Prem Pro CC - so that I can work as quickly as I would like to be working.
                    But - it seems that the 2014 project file does not open in CC - which is very disappointing.
                    I also tried to import the 2014 project file into CC via Bridge - but that does not work either.
                    Why isn't a 2014 file back ward compatible with CC ???
                    Now I have decided to leave Premier Pro 2014 alone - even if I have to start from scratch again in CC.
                    At least that way I won't be wasting my time trying to deal with constant crashes.
                    I am very disappointed with Premier Pro 2014 - I was looking forward to being able to use the new features and edit more productivley and
                    efficiently.
                    • 8. Re: Premier Pro 2014 is very sluggish
                      Hi Sapol,
                      SAPOL wrote:
                      Kevin hi -
                      Check out the system requirements. You must be running OS X 10.8, or later. Update and you should have a better experience.
                      Backward compatibility is not a feature of Premiere Pro. Sorry.
                      Kevin
                      • 9. Re: Premier Pro 2014 is very sluggish
                        Thanks for the tip Kevin - I will now update to OS 10.8 and see what happens with Premier Pro 2014.
                        If it is that simple I will be wrapped.
                        • 10. Re: Premier Pro 2014 is very sluggish
                          Hi Mike,
                          mdsunc30 wrote:
                          Hi Kevin,
                          Is this updated to work with Premiere Pro CC 2014?
                          Kevin
                          • 11. Re: Premier Pro 2014 is very sluggish
                            Cool. Let us know if that works.
                            Kevin
                            • 12. Re: Premier Pro 2014 is very sluggish
                              I will try uninstalling and reinstalling the color suite as I don't know if Red Giant link automatically updated them for CC 2014.  Thanks for the tip and I'll let you know how it turns out.
                              Best,
                              Mike
                              • 13. Re: Premier Pro 2014 is very sluggish
                                I uninstalled my Red Giant software and then reinstalled the updated version and I have not noticed the crashing like I was before.  Thanks for the advice as that seemed to help out quite a bit.  I am still having an issue where nearly every time I export from Premiere Pro to AME and have AME set to Open CL, about half way through the export AME will crash.  If I set AME to "Software Only" the export goes through without any problems.  This occurs when I'm exporting clips that have the Red Giant filters and it also occurs when I'm exporting clips with no filters at all.  I would really like to be able to export using the GPU Acceleration because it will speed up my workflow tremendously (especially when I'm exporting long sequences with lots of filters).  Please let me know if you have any idea why this is happening as well as what might fix it.
                                Mike
                                • 14. Re: Premier Pro 2014 is very sluggish
                                  BobanskyBh Community Member
                                  this is the common solution for laggy/crashing PPCC2014, worked for lots of people....
                                  In the finder menu click and hold on the GO menu.
                                  Hold the option button and the User library menu will show up.
                                  Click the User Library.
                                  In that folder go to preferences and find the adobe folder.
                                  Right click on adobe folder and click get info.
                                  In the Sharing & Permissions section there should be three names. All should say Read & Write next to them.
                                  Unlock the lock, switch them all to read and write. Then click on the little gear directly under the names or to to the left of the lock and in the pulldown click on "apply to enclosed items. Then lock the lock again.
                                  Now go to your OS Hardrive and click on Users, your user name, Documents.
                                  Find the adobe folder there. Right click on adobe folder and click get info. In the Sharing & Permissions section there should be three names. All should say Read & Write next to them.
                                  The lock the lock again.
                                  Wait 1 minute.
                                  Then launch Premiere.
                                  • 15. Re: Premier Pro 2014 is very sluggish
                                    Okay I just tried it, I'll give an update if it works or doesn't work.
                                    Mike
                                    • 16. Re: Premier Pro 2014 is very sluggish
                                      ggriswold@cox.net Community Member
                                      Updating my video card driver did the trick for me...
                                      • 17. Re: Premier Pro 2014 is very sluggish
                                        ganeszu Community Member
                                        I'm experiencing the same issue. Premiere Pro CC 2014 unexpectedly stops working on my Windows 7 32GB / Quadro K4000 machine and freezes. I was running the previous version of Premiere Pro CC with no crash issues.
                                        • 18. Re: Premier Pro 2014 is very sluggish
                                          Kevin -
                                          I have now updated to OS X 9.4 - after being told that Premier Pro 2014  has been optimised to take full advantage of the latest Mac OS.
                                          I was very much hoping that I could now be editing seamlessly with Premier Pro 2014 - after the latest Mac OS update.
                                          Sadly tho - I have had lots of freeze frames on the time line - or - else the picture just turns black.
                                          I have been trying to get a project edited for most of yesterday - but this morning I have given up on working with Premier Pro 2014.
                                          The time line plays and the sound plays - but the picture has either frozen - or it as gone to black.
                                          This happens quiet often - and then everything seems to be OK for a short while - before it happens again.
                                          What could be causing this ???
                                          I have now gone back too editing in Premier Pro CC - which has always been very stable and works very well - with no problems at all.
                                          I am on a 2012 iMac  3.4 GHz - Intel Core i7 - with 16GB RAM
                                          Any thoughts would be greatly appreciated.
                                          Thanks kindly
                                          Emmil...
                                          • 19. Re: Premier Pro 2014 is very sluggish
                                            Hi Mike,
                                            Glad to hear that the updated plug-ins have solved at least of your issues.
                                            Regarding AME crashing on export, are you running OS X 10.9.4 yet? Your other post indicates you are on OS X 10.9.3. If you are on OS X 10.9.3, please update to OS X 10.9.4.
                                            Kevin
                                            • 20. Re: Premier Pro 2014 is very sluggish
                                              So I use the following instructions posted by BobanskyBH and it seems to have worked perfectly!
                                              Wait 1 minute.
                                              • 21. Re: Premier Pro 2014 is very sluggish
                                                AzzieScott Community Member
                                                Hi, After my recent update to the latest version of Premiere Pro 2014 I have been experiencing sluggish playback and freezing as well. Sometime I can't even quit my project and have to force quit. I wa editing a simple timeline of dslr footage 1080 res and its like it was struggling with this footage. before my update never had issues like this. Before this update I was editing a 4k timeline with no issues, no its freezing and super sluggish. I tried uninstalling and reinstalling the software and reset my preferences and still same results. Im on MAV 10.9.4 8 core MacPro SSD 24 gigs Ram.
                                                • 22. Re: Premier Pro 2014 is very sluggish
                                                  Hi AzzieScott,
                                                  You have symptoms of the permissions in your preference folders set to "read only." They need to be set to read/write. See this blog post: fixing permissions problem that impedes start of Adobe applications | After Effects region of interest
                                                  Note that you are not merely resetting preferences, you're changing permissions of those folders. After you've done so, report back with the results.
                                                  Kevin
                                                  • 23. Re: Premier Pro 2014 is very sluggish
                                                    deathbychinatv Community Member
                                                    I have a very similar problem.  I have the latest Mac Pro and when I installed 2014, I can't export movies anymore without getting the error message "system out of application memory."  The activity monitor shows Premier and the Kernel task sucking huge amounts of memory.   Anybody know a workaround?  This sucks!
                                                    • 24. Re: Premier Pro 2014 is very sluggish
                                                      Hi Kevin, I'm going to try that and see if it works, but my question is WHY? do we need to do this? should PPCC automatically configure itself. its seems a little backwards. Its like hey everyone, upgrade to the latest with all these great features, but you need to go into these settings and configure your preferences for it to work properly! Just curious?
                                                      • 25. Re: Premier Pro 2014 is very sluggish
                                                        Hi AzzieScott,
                                                        Permissions are set correctly if you do a clean install of Mac OS X 10.9. However, if you update OS X (much more common these days), the updating process from one version of OS X to the next version of OS X sets the permissions incorrectly. We are working with our partners at Apple to fix the issue, but with the current version, some users are still having problems. This is the issue I see hitting Mac people on Mavericks most frequently.
                                                        Bobansky has the method here: Re: Premier Pro 2014 is very sluggish
                                                        It's frustrating, I know. Sorry for all the problems you're having. I've been there too.
                                                        Kevin
                                                        • 26. Re: Premier Pro 2014 is very sluggish
                                                          Hi DBCTV,
                                                          I replied to your other post, it seems to be a separate issue.
                                                          Kevin
                                                          • 27. Re: Premier Pro 2014 is very sluggish
                                                            Kevin, thats the thing I did a clean install of my OS 10.9 and then installed a clean of PPCC.But trying what you suggested now. Will report back soon.
                                                            • 28. Re: Premier Pro 2014 is very sluggish
                                                              Thanks, Azzie.
                                                              My colleague also suggests to repair Disk Permissions on your Mac HD using Disk Utility for good measure. Let us know what happens.
                                                              Kevin
                                                              • 29. Re: Premier Pro 2014 is very sluggish
        This didn't solve my issues..
        • 31. Re: Premier Pro 2014 is very sluggish
        As I said, your issue seems to be a different one. The fix I mentioned is not a catch all for everyone. Sorry you continue to have issues. We can work on your problem on your own post.
        Kevin
