3 Replies Latest reply: Jul 4, 2014 9:56 AM by SFnLS RSS
    Remove border from a custom preset
    Ziji Man Community Member
      I created a custom preset in Lightroom. It has the same border in the preset as seen in the photo below.
      I want to keep the preset I created, however I definitely don't want the white border to be on all of my photos.
      How can I remove only the white border? I have searched and can't find any option to remove the white border. I have some photos I need to finish fast and this has put the brakes on everything. Please help.
      Thank you!!
        • 1. Re: Remove border from a custom preset
          SFnLS Community Member
          Check down at the bottom of the adjustments panel. Looks like the preset has Post-Crop Vignetting turned on. Click the little switch icon in the upper left corner of that section and you'll turn off vignetting.
          • 2. Re: Remove border from a custom preset
            Thank you so much, that solved the problem!!!
            • 3. Re: Remove border from a custom preset
              You're welcome. Hope your photo processing goes well for you.
              The Post-Crop Vignetting panel is worth some experimentation time. You can really achieve a wide range of effects by manipulating the sliders.
              Solid black or white borders come from Amounts of -100 or +100, and the rounded corners on the preset you showed, as well as the width of the 'border' come from the Midpoint and Roundness sliders. The feather at 0 is what made the edge sharp.
              In any case this adjustment is a way to get a simple border inside Lightroom without resorting to taking the image out to something that understands layers like Photoshop or other applications that let you stack a border on top an image layer.
