This is a very annoying problem while generating release build files. Here is the steps I did while buiding:
1. Select Project > Export Release Build
2. Select Signed Native Installer
3. Import certificate
4. Click Next.
I always got the following error:
I have the following setup:
OS: Windows 8.1
System type: 64-bit
Flash Builder Version: 4.6 Premium
Installed FB: FlashBuilder_4_6_LS10.exe
Please help. This is giving me a lot of headaches for a couple of days now.
I tried installing windows 7 32-bit operating system and I no longer have problems on exporting release builds. I'm just wondering if Adobe released Flash Builder 4.6 for x64 operating systems.
Additionally, here's the stack trace:
java.io.IOException: Platform conversion failed. Process exited with error 5. Output was "[ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: EndUpdateResource: Windows Error #5" errorID=0]
at com.adobe.air.nai.NativePackager.conversionFail(NativePackager.java:222)
at com.adobe.air.nai.NativePackager.invokePlatformConversion(NativePackager.java:203)
at com.adobe.air.nai.NativePackager.createPackage(NativePackager.java:92)
at com.adobe.flexbuilder.multisdk.apollo.export.AIRNativeInstallerPackager.create(AIRNativeInstallerPackager.java:129)
at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionManager.doExport(ExportReleaseVersionManager.java:586)
at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionWizard$1.run(ExportReleaseVersionWizard.java:208)
Message:
I also suspect this is because of the following settings:
Eclipse.ini
FlashBuilder.ini
Please click the image for more clearer view.
Notice that the plugin used is not intended for x64 processors.
Please help.
I see this similar issue reported in Apache Flex but not yet fixed:
[FLEX-24594] ADT fails with exit code 5 (Unknown error) - ASF JIRA
In case any one finds this later on, I had this same issue but I fixed if by re-linking my Library Path files (even if they look correct they don't seem to connect for some reason) this resolved my issue, hopefully this is easier to do than re-installing or installing a fresh operating system to get it done.
