In my 23.98 timeline, I have several clips that were shot at 24.00 fps on a RED Dragon. Premiere CC (2014) is showing the wrong timecode numbers, in the timecode display and also in exported XMLs. If I look at the clip properties window, it shows the correct start frame.
For example, one clip shows a beginning timecode of 14:23:12:02. If I open this clip in other software (Resolve, RedCine-X), the starting timecode is shown as 14:24:03:22. Premiere's properties dialog shows the following (correct numbers). This is causing a big problem, because I can't send a timeline to other software using XML.
Red R3D Details:
Camera Firmware Version: 5.2.16
Camera Sensor: DRAGON S35
Minimum Color Version: 2
Resolution: 5568x3132
FrameRate Num: 24000
FrameRate Den: 1000
Reel ID: 005
Timecode Preference: Absolute
Edge Timecode: 01:51:17:07
Absolute Timecode: 14:24:03:22
In addition to the timecode problem, Premiere is also showing the wrong tape name for these clips. For example, it shows A005_C012, where it should be A005_C012_0620IR. This makes it impossible to send an XML to other software.
