CFFlush and javascript window.open
Jul 10, 2007 Jul 10, 2007
I have need to submit or kick off multiple requests and have them process at the same time or synchronously. I've written the following code to do just that which I can put into a loop.
</head>
<script>
window.open("ScriptFlushTest2.cfm");
</script>
Starting Script Flush Test 1.<br>
<br>
<cfflush>
<body>
It seems to work fine. Is there anything wrong with this method or is there a better way?
Thanks.
P.S. CFMX7
Advanced techniques
472
Rather than subjecting the user to all these browser windows opening, you might want to open them in little bitty iframes.
Contributor ,
You might like to look into Ajax to achieve this type of functionality. Personally I use hidden frames in a similar fashion to what Dan suggests - make them invisible and then tell them to run whatever you want. Its also quite easy to send results back to the calling page.
below is an example - the frame structure is usually placed in default.cfm (or index.cfm or whatever) and then use javascript to pass scripts to the frames:
Jul 11, 2007 Jul 11, 2007
I see your points however this time this was not intended to be a user run program but a scheduled job run on a server where if, heaven forbid, there ever was an error I would be able to view the page and correct it. There are other "pop ups" in our application that could be hidden so I will imploy your suggestions there.
Thank you both.
If it's a scheduled job your approach won't work at all because you are using javascript, which runs from the client browser.
Our scheduled jobs run in a browser. They are scheduled using Windows scheduled tasks that open a browser and run a particular cfm.
Thanks.
Documentation
