Flex RemoteObject and Server Session State
Avatar
Former Community Member
I've been trying to use mx:RemoteObject to access server
session state. I write the following code:
<mx:RemoteObject id="objSession" source="servlet" />
in flex.war web.xml -->
<servlet>
<servlet-name>servlet</servlet-name>
<display-name>Provides access to the current session;
for use with RemoteObject
</display-name>
<servlet-class>flex.bootstrap.BootstrapServlet</servlet-class>
<init-param>
<param-name>servlet.class</param-name>
<param-value>flex.server.j2ee.remote.Session</param-value>
</init-param>
</servlet>
What am I doing wrong? I don't have the flex data server. Do
I need the server?
Also, Is there a better way to do this?
--thanks for any help. Bret Mullinix
Avatar
Level 1
You will need flex data service (lifecycle data service). You
have to deploy web.war in your servlet container.
Avatar
This isn't the way to do things in FDS. We no longer connect
to servlets
directly. Out of the box we want you to write a plain old
java object
and compile it into /WEB-INF/classes (or jar it up and put it
in
/WEB-INF/lib). You then create a remoting-service destination
for your
class and then specify this destination in your
<mx:RemoteObject> tag in
your client code. (Remember to restart the web application
after making
any configuration changes).
From your POJO you can get to the session through the static
thread-local flex.messaging.FlexContext.getFlexSession().
This returns
an implementation of flex.messaging.FlexSession. If your
request was
made over HTTP then the implementation will wrap the J2EE
HttpSession
and delegate any calls to it (such as getting and setting
attributes).
Alternatively, if you know your POJO is always going to be
contacted
over HTTP you can ask the the HttpServletRequest through
flex.messaging.FlexContext.getHttpRequest() and then get the
HttpSession
from that (via the usual getSession() method).
Remember that if you use flex.messaging.FlexContext etc... in
your own
java object you'll need to add
/WEB-INF/lib/flex-messaging.jar and
/WEB-INF/lib/flex-messaging-common.jar to your classpath.
Pete
Avatar
Level 1
Is there any way to make a new FlexSession if one doesn't
exist (in java)?
I am having a problem integrating a flex app into an existing
web app that has session variables set, but when I make a
RemoteObject call it creates a __flexSession and deletes all my
other session info. After making the RO call once, and the
__flexSession is created, everything works fine . . . I have a
work-around right now that involves making a RO call before
entering the app, but I would like to start the session in java if
possible. This seems to only happen on my Tomcat 6 (jdk 1.6)
server. When I use JRun4 sp6 it seems to handle the addition of the
__flexSession attribute into the session.
Kevin
Avatar
Hi Kevin,
Which version of FDS or LCDS are you using?
If you're using J2EE sessions, then the Flash Player would
have to send the
cookie via HTTP that contained the jsessionid along with your
RemoteObject
request in order for you to be in the same session. Can you
use an HTTP sniffer
to see whether this cookie is being sent?
Pete
Hello kgeiwitz,
doesn't exist (in
> java)?
existing web app
> creates a __flexSession and deletes all my other session
info. After
> making the RO call once, and the __flexSession is
created, everything
> works fine . . . I have a work-around right now that
involves making a
> RO call before entering the app, but I would like to
start the session
> in java if possible.
> Kevin
Avatar
Level 1
Pete,
LCDS 25
When I switch the protocol to http, so I can see it in the
sniffer, everything works fine (tomcat and jrun).
So . . . maybe it has something to do with https ? ? ? (still
not sure why it works in jrun but not in tomcat)
I tried adding the JSESSIONID to the response header of the
jsp that has the swf, and as a parameter of the swf . . . neither
worked.
Avatar
It may be something more complicated than this, but let's
cover the basics
for HTTPS first before we start tracking down session
cookies...
1. If you need to make a secure connection from the Flash
Player, then the
SWF should be loaded via HTTPS. If you're using an HTML
wrapper be sure that
the movie url for the SWF is HTTPS - if it's a relative URL
this would mean
that the HTML wrapper itself would have to be loaded via
HTTPS.
2. MSIE has problems with certain HTTP response headers when
using SSL -
various combinations of Pragma: no-cache, Cache-Control:
no-cache, or Expires
response headers can cause problems depending on the version
of HTTP, whether
chunked or gzip encoding is being used, and the version of
MSIE (with the
most problems seem to occur with MSIE 6).
3. If you're using a crossdomain.xml policy file, watch out
for a Firefox
only bug where by if the Flash Player requests a
crossdomain.xml from a URL
that specifies a port and is challenged by Basic Auth the
subsequent request
will not work.
In general, when debugging HTTP/HTTPS issues it pays to use a
sniffer to
watch the traffic between the client and the server. Since
you're having
issues with HTTPS, you'll probably need to use a client-side
proxy to do
the sniffing for you. Paros Proxy is a good example of a
simple sniffer that
you can easily configure MSIE to use as a proxy and thus
watch the HTTP headers
and bodies for the request and response before they are sent
encrypted via
HTTPS.
Hello kgeiwitz,
> Pete,
> LCDS 25
the sniffer,
(still not
the jsp that
worked.
Avatar
Level 1
NEVER MIND . . .
I switched my destination to the secureAMFChannel and
everything is working.
SORRY FOR WASTING YOUR TIME
Avatar
Hey Kevin,
No worries, glad to hear that you tracked down the issue.
Since you are using secureAMFChannel, be mindful of the MSIE
issues and HTTPS
as different web servers may add different headers based on
their default
configurations. You may want to set the
<add-no-cache-headers> property to
false for the endpoint configuration too to be sure that LCDS
isn't adding
its own no-cache headers that may complicate the issue.
Pete
Avatar
Level 1
Pete,
I am currently using the default channel-definition that came
with lcds, which has the add-no-cache-headers property set to false
(in services-config.xml).
Thanks for the warning, and your time.
Kevin
