1. Re: How to import footage from Sony F55 to Premiere CS6?
petergaraway Jul 4, 2014 11:17 PM (in response to JR Dungan)For CS6 you will need to download the Sony RAW plugin found here:
http://www.sonycreativesoftware.com/plad-rw1
Best,
Peter Garaway
Adobe
Premiere Pro
2. Re: How to import footage from Sony F55 to Premiere CS6?
BobanskyBh Jul 5, 2014 12:51 AM (in response to JR Dungan)Hi, in case you don't shoot RAW (you shoot in XAVC codec, ), you will need to convert it with some external converter to Prores, or some other format.
But, if you install CC, you will be able to load this files natively.Cheers!
3. Re: How to import footage from Sony F55 to Premiere CS6?
JR Dungan Jul 6, 2014 12:13 PM (in response to JR Dungan)Thanks. When I try and import the file, right now I just get a green blank screen when the clip comes up. (I have successfully loaded the plug-in). I just dragged and dropped the clip plus its supplementary files into the project, and is said that 3 of the supplementary files weren't compatible (one is .mxf.bmp and one is .BIM). The .mxf clip itself is what appears, but it is just blank. I'm wondering if I'm loading the clip wrong?
Jason
