Show 2 replies
1. Re: Converting from .doc to .html
AnthonySlay Jul 11, 2007 10:36 AM (in response to Joshtsmom)That's odd. From my experience, roboinfo does an excellent job preserving the format of word documents. Have you tried a copy past method from word to a roboinfo topic or are you doing it using a different method? What version are you using. -
2. Re: Converting from .doc to .html
5.0Montecarlo Jul 12, 2007 5:20 PM (in response to Joshtsmom)This all depends on how you have your cascading style sheets (.css) setup. If, for instance, you have a heading in your word document formatted as Heading 1 whatever formatting associated with it in Word (bullet points, font size, font type, color, etc.) will carry through to Robo unless you apply a certain style sheet to it after you import it into Robo. Style sheets in Word are typically visible next to the font type in the standard toolbar. If not present, they can be located under Format > Styles and Formatting. You can set up a style sheet that formats Heading 1 (or whatever you choose to call it) a certain way, Normal a certain way, etc., apply this style sheet to each of your procedures, and all of the formatting associated with that style sheet will present itself. This saves tons of time as well as keeps everything consistent. I hope this helps.
Gary
