stored pro
Guest
Jul 11, 2007 Jul 11, 2007
hi i have a mysql stored procedure and i get an error when i try and call it, using
<cfstoredproc procedure = "sp_test23" dataSource = "#application.ds#">
</cfstoredproc>
<cfdump var="sp_test23">
any ideas why i would be getting this error
The system has attempted to use an undefined value, which usually indicates a programming error, either in your code or some system code.
Null Pointers are another name for undefined values.
Advanced techniques
1.8K
Guide ,
That code doesn't create any variables.
If the procedure returns a resultset use CFPROCRESULT. If it uses output variables, use cfprocparam type="OUT"
Guest
ok,
the stored procedure is
create procedure sp_test()
select * from s_table;
so how would i call all columns?
Guide ,
CFPROCRESULT returns a query object. You can loop through it like a regular cfquery or access the column names via ColumnList variable: #yourQueryName.ColumnList#
Guest
ok so would this code work?
where does the RS1 come from ?
<cfstoredproc procedure = "sp_test" dataSource = "#application.ds#">
<cfprocresult name = RS1>
</cfstoredproc>
<cfdump var="RS1">
Guide ,
RS1 is the name of the resultset (query) variable. The name should be in quotes.
<cfprocresult name = "RS1">
</cfstoredproc>
You must # signs around the cfdump variable.
<cfdump var="#RS1#">
That's the typical syntax for ms sql. Theoretically it should work for mysql IF the db version and driver support stored procedures.
Edit - code correction
Guest
ok i have tried that but i get this error.
Guide ,
Did you put quotes around the resultset name?
Guest
ok yes changed that and i get
Variable RS1 is undefined
Guide ,
On which line? The cfdump?
Originally the procedure name was sp_test123 and now its sp_test. Are you running the correct stored procedure? Does it return results when you run it in mysql?
Guest
no on this line
<cfprocresult name = "#RS1#">
any idea?
many thanks for this
Guide ,
Here "RS1" is a constant. So don't put # signs around it. Try this:
</cfstoredproc>
Guest
no good i still get this error
Guide ,
Did you copy the code in my last example exactly?
Guest
yes i did
Guide ,
And are you certain you're running the correct procedure? Does it return a resultset when you run it in mysql?
Guest
its def sp_test i ran a show procedure and it showed up in mysql
Guide ,
That's not enough. Run it in mysql. Does it return a resultset?
Guest
ok this is the error in mysql
There seems to be an error in your SQL query. The MySQL server error output below, if there is any, may also help you in diagnosing the problem
ERROR: Unknown Punctuation String @ 98
STR: </
SQL: <cfstoredproc procedure = "sp_test" dataSource = "#application.ds#">
</cfstoredproc>
Guide ,
No. I mean run the procedure in mysql (command line)
mysql> call sp_test();
Guest
i cant its an external web server
Guide ,
Sorry I have to go.
Ok. Its a remote db. I'm not seeing why can't you connect to it. But I tested your procedure with CF and it works with mysql5 and connector/j 5 driver. So it suggests you may be using different procedure code.
MYSQL:
select * from stable;
CF:
<cfstoredproc procedure="sp_test" datasource="MySQL">
<cfprocresult name="RS1">
</cfstoredproc>
Good luck
Participant ,
Jul 12, 2007 Jul 12, 2007
You still aught to be able to do what he suggested using a <cfquery>
IE:
<cfquery name="somename" datasource="yourdatasource">
call sp_test();
</cfquery>
<cfdump var="#somename#">
Documentation
