1. Re: Feedback / Submit an idea don't Work (Page not found) || Multiline Regular Expression Search
Randy Edmunds Jun 27, 2014 7:50 AM (in response to Dirk Persky)Hi Dirk,
This Forum is now the feedback system!
Edge Code CC is a re-branding of the Brackets Project. I thought there was a card for that feature in the Brackets Product Backlog , but I didn't see it in a quick search. You're welcome to add your vote for any features there, or file a new issue if you can't find it.
Thanks for your feedback,
Randy
2. Re: Feedback / Submit an idea don't Work (Page not found) || Multiline Regular Expression Search
Peter Flynn (Adobe) Jul 8, 2014 11:37 PM (in response to Dirk Persky)Hi Dirk,
Thanks for reporting the broken links -- we'll look into that. As Randy said, you're welcome to just post suggestions & issues here in the forum, though.
Regarding multiline regexp search: that is possible in Edge Code, with some limitations:
- To search multiple files, use the Find in Files command, and then use any regexp containing "\n" -- it will match the newlines correctly.
- To search a single file, right-click the file and chose "Find In..." (it will behave like Find in Files, but limited to that one file)
- Caveat: you can't use the multiline $/^ anchors in your regexp
- Caveat: there's no workaround for using the Replace command with multiline regexps
The latest Brackets release 0.41 fixes both the caveats listed above -- though you'll still have to use the "Find In..." workaround (or "Replace In..." for Replace). We eventually plan to further improve this -- you can watch the full multiline search/replace item on our feature backlog for updates.
Hope that helps,
- Peter
