I want the learner to be able to access any topic listed in my TOC but currently this function doesn't work when I preview in the HTML browser. I have checked the TOC 'Enable Navigation' setting and de-selected the 'Navigate Visited Slides Only'. I'm working on a MAC with delivery intended for IPads and tablets, if that matters. Why can't I navigate to any topic I want? What else do I need to set?
Thanks in advance.
Hi there
Do you have Quiz slides? If so, it depends on your quiz settings. If each question must be answered, navigating beyond the first unanswered question will be disallowed.
Cheers... Rick
Hi there
Cheers... Rick
Ah. that makes sense. I'll change quiz setting preferences right now and
let you know.
Check which option you currently have selected under Quiz > Settings > Required.
If it's NOT set to Optional, try that setting and see if your navigation then works after republishing.
Thank you Rod. I expect this to solve my problem.
Chris
You both gave me the correct answer so...how do you both get points for your recommendation? Thank you for your help.
LOL, give 'em to Rod.
I couldn't care less about points. My goal isn't to accumulate points but to just help out if I can.
Cheers... Rick
Your answer not only solved the question I asked but gave me insight into
another problem I was having in setting up branching. Once I changed the
Quiz setting, my branching from question slides worked! I thank you both
for the tip.
