Hi, and thanks for any help you can offer on this issue...
I'm using the WebHelp/Printed Documentation single-sourcing
methodology in RH 6, and I've established two Conditional Build
Tags - "OLH" (Online Help) and "Printed". For the most part, the
conditional tags are awesome... except when my content includes
HTML tables. If a table exists within a set of conditional tag
material, material that exists AFTER the table (and outside the
Conditional Tag) will be omitted from the finished output (i.e.,
regardless of the Single Source Output method used for finished
product generation -- WebHelp or Printed Documentation.) In a few
instances, only some of the material after the table is omitted.
For example, in a full document that includes a specific
paragraph and a table of data that I want to exist only in my
printed docs. I apply the "Printed" tag to this paragraph and
table. Once I generate the WebHelp layout (or even Preview it and
apply the appropriate Conditional Build Tag Expression), the tagged
"Printed" content is left out, but so is all of the content that
followed it... even though I didn't apply a conditional build tag
to that material.
I have a work-around, but it sucks... If I remove the tables
(and re-format the content to just text), all is just fine, and the
build tags work properly. The thing is, I want to use tables in my
content.
I'd love a WYSIWYG solution, but if I have to edit the code,
I'll live... I just need to know what and where to edit (I've
played with the '<p> <style="x-condition: Printed;">'
tag, and added closing "</p>" and "</style>" tags, but
that hasn't worked).
Thanks for taking the time to review this, and for any help
you can give.
