In FM 8 (Windows XP), how can you show a specific condition (A) when it is the only condition applied to a block of text? I have some text that has two conditions applied (A+B), and I want that text hidden.
I've tried different approaches in the Build Expression dialog box, but get an "Invalid expression" message no matter what I try. What I need Frame to do is "Show A NOT A+B."
We're going to newest version of FM later in the year, so if this cannot be done in FM 8, can it be done in the current version of FM?
Thank you for your help.
Try using the original FM condition tag approach (Show/Hide logical OR model) and simply set condition A to show and condition B to hide. Any text that has both tags applied will also be hidden.
Arnis,
If by "the original FM condition tag approach", you mean the Show as Per Condition Show/Hide shuttle boxes, then I do not believe there is a way to specify "OR logic" based on the hidden tags. Before the introduction of conditional expressions, FM always showed conditional text if any of the applied tags were shown, as Show as per Condition still does. I agree with Winfried on this one.
--Lynne
Hi Gloria,
With Show as per Condition FrameMaker will show all text which has A applied, no matter, if other conditions are applied as well. This is the OR logic.
If A should be shown and AB should be hidden, you must use this expression:
"A"ANDNOT"B"
A will be shown.
Then the expression checks for B. and hides all text with B.
I admit I experiment, if I want to achieve a specific result, specifically when there are more conditions involved.
Probably this is easier in FrameMaker 12 as it allows to use brackets.
Best regards
Winfried
With OR logic, hiding B will hide B along with any combined tags containing B (i.e. A+B).
Thank you all very much for your replies. Winfried's approach worked. Sorry, Arnis, the others seem to be right about how the basic logic works. Simply telling FM to show A and hide B does not hide text that has both conditions applied. The ANDNOT expression Winfried provided does work, however. Thanks again!
Sorry for any confusion - I was visualizing the AND logic truth table and thinking it was OR; Winfried and Lynne are absolutely correct. [That's what you get for not trying it out... ]
Don't worry about it, Arnis. You're allowed a mistake once every few decades.
--Lynne
