1. Re: I can't login to Acrobat.com from Captivate 6 to report quiz results.
Jeff A Wright Oct 9, 2012 10:16 AM (in response to ahaltman)Moving this discussion to the Captivate Quizzing/LMS forum. It will likely be more efficient though if you contact our support team to resolve your login difficulties.
Message was edited by: David Kastendick
2. Re: I can't login to Acrobat.com from Captivate 6 to report quiz results.
sunrisestorm Nov 28, 2012 8:04 PM (in response to ahaltman)I'm having the same problems and so is a client. We're going around in circles and can't get hold of anyone at Adobe. Yes, unbelievable that it doesn't work. Have you had any result?
3. Re: I can't login to Acrobat.com from Captivate 6 to report quiz results.
RodWard Nov 29, 2012 12:32 AM (in response to sunrisestorm)Adobe websites seem to use some kind of common login authorisation system. Some time ago it was damaged and caused issues with logins, so it was rebuilt, but some data was lost in the process.
You need to go to the Adobe login page and use the options there to have your Adob ID password reset. Once that is done, you will be able to log in again successfully.
4. Re: I can't login to Acrobat.com from Captivate 6 to report quiz results.
sunrisestorm Nov 29, 2012 6:08 PM (in response to RodWard)Thanks Rod, Unfortunately this does not work, even though I was assured by Adobe tech assistance after I went through the whole process that it would.
Made a second call and spent nearly three hours with Adobe tech assistance yesterday, with them accessing my computer and they still have not been able to solve the problem, which is occurring on at least four other installations in different locations and companies that I know of. They checked all settings and could not even sign in or post results using their own Adobe IDs.
They are investigating to try and find the problem as it seems to be more serious than just resetting passwords. Sigh. Will let you all know when, hopefully, we get a solution.
Cheers
5. Re: I can't login to Acrobat.com from Captivate 6 to report quiz results.
training4me Dec 14, 2012 9:38 AM (in response to sunrisestorm)We are getting the same results (or lack of results) with version 5.5 and adobe.com. Didn't they moved the login location on acrobat.com? Maybe they didn't update captivate to go to the right login location? Who knows but this and the email not working is frustrating. Not everyone has a big LMS. :-(
6. Re: I can't login to Acrobat.com from Captivate 6 to report quiz results.
sunrisestorm Dec 14, 2012 4:05 PM (in response to training4me)Yes, I've tried with Captivate 5 as well and it doesn't work. Meanwhile, total silence from Adobe "support". Ha!
7. Re: I can't login to Acrobat.com from Captivate 6 to report quiz results.
marchtm Mar 9, 2013 11:56 AM (in response to sunrisestorm)I am having this issue as well with Captivate 6. Very frustrated with the lack of support from Adobe!!!
If anyone is considering purchasing this, take your time and research other options first!
8. Re: I can't login to Acrobat.com from Captivate 6 to report quiz results.
oschmidt74 Jun 5, 2013 9:08 AM (in response to marchtm)I have the same problem but strangely I had a working solution in mid May. Now the same quiz (minor formating changes) does not work anymore. No way to post the results to Acrobat.com. Error message is "Acrobat.com Login Error."
My logins all work when I'm logging into Acrobat.com. If I use a wrong login in the quiz to post results it recognizes the wrong login credentials and gives another error message.
9. Re: I can't login to Acrobat.com from Captivate 6 to report quiz results.
SisMoon12 Jun 8, 2013 12:55 PM (in response to marchtm)In Captivate 7, Adobe support and Acrobat still suck. I posted a question in the Acrobat.com forum for the same login error message. Let us see how long it takes that group to respond.
hold your breath
SisMoon
10. Re: I can't login to Acrobat.com from Captivate 6 to report quiz results.
squids38 Jul 12, 2014 3:09 PM (in response to RodWard)Did it didn't work
11. Re: I can't login to Acrobat.com from Captivate 6 to report quiz results.
gogetconnie2 Jul 15, 2014 8:32 AM (in response to squids38)This worked for me a few weeks ago, but it no longer works. I have reset my password multiple times. When I enter my configure acrobat.com settings I get the message: Unable to create folder. Verify your network connection.
12. Re: I can't login to Acrobat.com from Captivate 6 to report quiz results.
Mayank_M Sep 19, 2014 9:54 AM (in response to gogetconnie2)Hi There,
Please follow the below steps to fix acrobat.com reporting :
Steps to apply the patch :
- Close Adobe Captivate
- Click on the following link to download the patch on your desktop: https://workspaces.acrobat.com/?d=a62kxXcme8dcPvi3*cKIMA
- Unzip the downloaded file.
- Now open “Captivate installation location\ SWF_Components\AlternateReporting”
- Replace “AlternateReporting.swf” from the .swf you downloaded on Desktop (Step 3)
- Launch Adobe Captivate and configure Acrobat.com on “Edit -> Preferences” window
Note : Make sure you republish all your projects
Mayank
13. Re: I can't login to Acrobat.com from Captivate 6 to report quiz results.
gogetconnie2 Oct 1, 2014 10:33 AM (in response to Mayank_M)I copied the fix into my directory. I can now login from the Publish settings and I do get a reporting area created in the Results Anaylzer. But now when I take the survey and post results I get an error. I click Post Results, I login and it connects, and then I click Send.
I immediately get Unknown Error.
14. Re: I can't login to Acrobat.com from Captivate 6 to report quiz results.
Moruibin Oct 22, 2014 8:41 AM (in response to Mayank_M)I am working with Captivate 7 and Quiz Results Analyzer Version 7.
I applied the patch and was able to get past the "Unable to create folder" issue in Captivate, and the new course is added to Quiz Results Analyzer.
Like gogetconnie2, however, I am also getting an "Unknown Error" when I try to post the results.
Is there an explanation or fix for this error?
