Is there a way in the Autonumber Format to add a return to create a blank line between items in a list? Right now, I can only do it by removing the Autonumber format for the new paragraph and then add it back in for the next line. Seems like there would be a way to add a building block for this.
In the Paragraph Designer for the auto-numbered format:
Basic > Space: Below Pgf: [ <set to more than the default> ]
If you put a \r in the autonumber format, it's going to add a return between the number and the paratext, unless you are using trailing autonumbers, which is rare.
Thank you, Error7103. Works fine. Obviously I'm new.
Error,
Good advice about Space Below. Unfortunately, though, \r does not work in an autonumber.
--Lynne
Now that I've actually tried it , it doesn't just not work, it vanishes as soon as you hit [Apply], whether \r or \x09.
Unicode hacks don't work either, such as
\u000d (CR, Carriage Return : ignored)
\u0085 (NEL, Next Line : renders as "?")
\u2028 (LS, Line Separator : renders as "?")
\u2029 (PS, Paragraph Separator : renders as "?")
If you actually want a forced return between the AN and the paratext, you have to type it as part of the paratext.
And it is somewhat unfortunate, because there are cases where you might want it, such as illustration captions
Figure 123\r
Caption Text String
Error,
Your example of a figure number and figure caption on separate lines is easily supported in structured documents. One solution would be to put the figure number in an autonumber but use a prefix consisting of a forced return (entered as \r or \n) as well. If the figure number and caption appear above the graphic, or at the start of some other element, another is to give the containing element a prefix of a space. Since the caption is a paragraph, that space and the caption would be in different paragraphs and could have different paragraph formats.
--Lynne
Is there a requirement that there be a blank line? It would normally be
best practice to create your paragraph format to have a large Space
After specified instead.
By blank line, I meant space below. A building block in the autonumber format to add a return would be nice. I used the recommendation in the reply from @Error7103. It worked just fine. I now have a paragraph tag for my lists.
