1. Re: Article Metadata
Neil Enns - Adobe Jul 16, 2014 1:12 PM (in response to -hans-)The article metadata has to be set before the article is published. Why can't you use the sidecar file?
Neil
2. Re: Article Metadata
-hans- Jul 17, 2014 4:21 AM (in response to Neil Enns - Adobe)We're completely producing out of Database. Sidecar has to be used with upload out of filesystem ...?!
Is there a way to script the foliobuilderpanel to set the metadata before publishing?
Thx for response
3. Re: Article Metadata
Neil Enns - Adobe Jul 17, 2014 6:24 AM (in response to -hans-)If you're producing out of a database how are you uploading your folio to DPS?
Neil
4. Re: Article Metadata
-hans- Jul 17, 2014 10:21 AM (in response to Neil Enns - Adobe)uploading from wthin database doesn't work untill now, so we're using the foliobuilder-panel for upload.
5. Re: Article Metadata
Neil Enns - Adobe Jul 17, 2014 11:02 AM (in response to -hans-)If you are using folio builder panel for upload then you should be able to use the sidecar.xml file. Create the sidecar.xml with information out of your database, and import it instead of manually adding each article to folio builder panel for the upload.
Neil
