3 Replies Latest reply: Jul 17, 2014 2:01 PM by Peter Flynn (Adobe) RSS
    Adobe Edge Code Error HELP!
    Boner Community Member
      When i try to make a new file it comes up with a error message it says Error creating file, An error when trying to create the file "name.type". The target directory cannot be modified.
        • 1. Re: Adobe Edge Code Error HELP!
          Peter Flynn (Adobe) Adobe Employee
          Are you trying to create a file inside the default "Getting Started" project?  You won't be able to do that because this folder is inside the app's install location, and the OS prevents you from modifying anything there without admin privileges.  If you open a different folder (File > Open Folder, or click the "Getting Started" heading in the sidebar and choose Open Folder), then you should be able to make a new file successfully.  Please let us know if not.
          Hope that helps!
          - Peter
          • 2. Re: Adobe Edge Code Error HELP!
            i did that but it still says the same thing when i try to create a new folder, what i did was what you said file open folder and clicked on the folder gettingstarted and opened it then tryed to go file new again but that didnt work. anything else that might work?
            • 3. Re: Adobe Edge Code Error HELP!
              You need to pick a different folder, other than Getting Started.  If you pick a folder located inside the Edge Code install location (such as Getting Started), you will not be able to create any new files or folders there.  If you pick a folder somewhere else, such as inside your Documents folder tree, then it should work.
              - Peter
