31 Replies Latest reply: Oct 30, 2014 6:04 AM by pfalzgraff RSS
    ERROR 604 KEEPS POPPING UP
    tony e key Community Member
      Hi, I keep getting a message window pop up in OSX Mavericks, telling me that there is an error 604 on my add ons.
      This is annoying to say the least. Does anyone know what may be causing this, how to fix it or is anyone else having similar problems with the latest CC 2014 installations?
      Many thanks
        • 1. Re: ERROR 604 KEEPS POPPING UP
          Carl Sun Adobe Employee
          Could you provide more details? When does the error pop up? When you launch Extension Manager CC? or when you launch Photoshop? Did this issue happen after you have installed a specific add-on? It would be great if you can upload a screenshot.
          • 2. Re: ERROR 604 KEEPS POPPING UP
            when2laugh Community Member
            WILL YOU PLEASE FIX THE EXTENSION MANAGER UPDATE - !!!
            • 3. Re: ERROR 604 KEEPS POPPING UP
              Hi Carl,
              Basically since installing Dreamweaver CC 2014 and Muse CC 2014 (I have installed others but only selected a few add ons for these two)...nothing seems to be installing on my machine at work. In particular I wanted to get Business Catalyst working - but Dreamweaver is having none of it.
              I've done all the "turn it off and on again". I've touched my nose with my elbow and span around twice and clicked the heals of my crystal slippers !! I have EVEN updated Extension Manager CC and manually downloaded the BC extension and tried installing it through that.
              All to no avail.
              I am considering a career in macdonalds now as compyooders just don't seem to like me.
              • 4. Re: ERROR 604 KEEPS POPPING UP
                Just in case this helps, Extension Manager is telling me that "The extension cannot be installed because licensing verification failed. The extension will not be installed".
                I don't know if this has anything to do with the reason that the other add-ons don't seem to work, but please hurry because my interview for "Glory Hole Operative" at MacDonalds is at 5pm (GMT) and i'd rather be a UI/UX -Digital Design professional than do that for a career but Adobe does seem to be pushing me in that direction... (sad face)....
                • 5. Re: ERROR 604 KEEPS POPPING UP
                  When you install any of extensions from Adobe Exchange, EM will check if you are entitled to install it. If the check failed, the error message above will pop up. Please ensure you have signed in with you correct Adobe ID and password.
                  You can quit all Adobe products, delete C:\Users\<UserName>\AppData\Local\Adobe\OOBE\opm.db (Windows) or /Users/<UserName>/Library/Application Support/Adobe/OOBE/opm.db (Mac), then retry. When Adobe ID Sign in dialog box pops up, sign in with correct information.
                  • 6. Re: ERROR 604 KEEPS POPPING UP
                    jonuroral
                    Same problem here.
                    I tried to install Kuler from creative.adobe.com both , but keep getting "The extension cannot be installed because licensing verification failed. The extension will not be installed" error.
                    Adobe ID and password is right. No problem there.
                    • 7. Re: ERROR 604 KEEPS POPPING UP
                      Mad Zathras Community Member
                      I'm getting this too. Error -604. No mention of licensing. Just unable to install any extensions. I can't even tell if extensions are working because I can't download one to try! Adobe needs to give us the option of manually downloading the extensions. This cloud stuff is apparently a bit difficult for them.
                      Using CC 2014, extensions for Photoshop. I deleted the file in: Macintosh HD:Users:XXXX:Library:Application Support:Adobe:OOBE
                      OS X Mavericks 10.9.4. But it was happening in 10.9.3 as well.
                      • 8. Re: ERROR 604 KEEPS POPPING UP
                        Yes, I find the fact that when the problem occurs, the "software" pushes us to a page on the adobe website which basically says "Go to forum" because we don't have an answer - just talk amongst yourselves for a while. NOT "contact Support". No. DOn't waste our time. Go and talk to other people having the same problem and sort it out yourselves. THEN, one of our staff can copy and paste the answer in our help system.
                        BRILLIANT.
                        The optimist in me thinks this is a brilliant business model and I'm planning to design and produce a whole raft of software that doesn't actually work, and the help system will be phone in chat line for hells angels and bikers.
                        Here's an idea. Why not TEST these add ons and make sure they work before making a big song and dance about "NEW SOFTWARE".
                        But then again, who am I to talk such lunacy? I do apologise.
                        • 9. Re: ERROR 604 KEEPS POPPING UP
                          jonuroral Community Member
                          My problem is solved. But have no idea how and why.
                          Yesterday got a notification from Creative Cloud which said Kuler was installed. After that I restarted PS, and now I can open Extensions as a window.
                          Weird stuff.
                          • 10. Re: ERROR 604 KEEPS POPPING UP
                            Error Code: -6xx
                            Failed online license check for Add-ons.
                            Solution: Contact the Adobe Exchange Online Forum for assistance
                            The solution, CLEARLY, does not lie within this forum, as the problem still remains.
                            In fact, there's lots of problems now.
                            • 11. Re: ERROR 604 KEEPS POPPING UP
                              kglad CommunityMVP
                              start here, Adobe Exchange
                              • 12. Re: ERROR 604 KEEPS POPPING UP
                                shuo_yang Adobe Employee
                                Could you try following steps to help us to find the root cause?
                                1.  Create a file called exmancoreliblog.yes and copy it to /Users/<name>/Library/Application Support/Adobe/Extension Manager CC/Log/
                                2.  Quit Adobe Creative Cloud Desktop Application
                                3.  Wait a while and relaunch Adobe Creative Cloud Desktop
                                4.  It will show 604 error
                                5. Goto https://creative.adobe.com/addons/my_addons to make sure you have enabled this add-on
                                6. Send ExManCoreLibrary.log to exman.beijing@gmail.com
                                Shuolei
                                • 13. Re: ERROR 604 KEEPS POPPING UP
                                  Hello,
                                  Attached is my log file.
                                  Should I leave the .yes file in the folder?
                                  Eric
                                  • 14. Re: ERROR 604 KEEPS POPPING UP
                                    Thank you very much for your log. We will investigate this and get back to you later.
                                    • 15. Re: ERROR 604 KEEPS POPPING UP
                                      fgregor Adobe Employee
                                      Hi all,
                                      We are aware of an issue where -604 errors can appear when users have previously downloaded a product from Add-ons/Adobe Exchange that has now been retracted by the producer.
                                      This issue should be resolved in the next 24 hours - please let us know if problems persist for longer than that.
                                      Thanks for your patience,
                                      Fraser
                                      • 16. Re: ERROR 604 KEEPS POPPING UP
                                        Thanks for helping get this straightened out! You guys are Adobe at its best.
                                        Eric
                                        • 17. Re: ERROR 604 KEEPS POPPING UP
                                          I’m afraid the problem persists.
                                          • 18. Re: ERROR 604 KEEPS POPPING UP
                                            Ah, sorry to hear that but thanks for letting us know. I can't see any record of your user having failed license checks today - so I wonder if this is actually caused by caching.
                                            Have you tried quitting and restarting the Creative Cloud desktop app? If so and the 604 error is still appearing, it would help a lot if you could send me the updated ExManCoreLibrary.log to fgregor@adobe.com by following the same steps you followed earlier.
                                            Thanks again for bearing with us!
                                            Fraser
                                            • 19. Re: ERROR 604 KEEPS POPPING UP
                                              Okay. I’ll give it a try.
                                              • 20. Re: ERROR 604 KEEPS POPPING UP
                                                Can anyone tell me whether they have tried removing all the add-ons listed at https://creative.adobe.com/addons/my_addons, and then waiting to see whether the 604 reappears?
                                                It would be good to know whether installing add-ons succeeds some of the time, or if the 604 errors are being returned each and every time you try to install something.
                                                We are working on this, so thanks again for your patience.
                                                Fraser
                                                • 21. Re: ERROR 604 KEEPS POPPING UP
                                                  I just did that.
                                                  • 22. Re: ERROR 604 KEEPS POPPING UP
                                                    Wahoo McDaniels
                                                    Greetings, all other folks battling with error 604. Here we are a week since the last message... still getting error 604 whenever I try to install any add-on. Any forward movement as yet?
                                                    Additionally (perhaps unrelated, but I figure it can't hurt to mention it), the Extensions option in the Photoshop Window menu is greyed out, so I can't even get to anything resembling the Exchange panel... and there doesn't seem to be any method by which I can enable it. All the reinstalling and fiddling in the world doesn't seem to have amounted to anything.
                                                    It's a biiiig pain, and I'd just love to get back to work.
                                                    • 23. Re: ERROR 604 KEEPS POPPING UP
                                                      I've been working with Adobe's engineers in Beijing on this one, and I keep sending them files and info and nothing yet. We (me and my IT department) have ruled out that it's my companies' proxy server or firewall. I had free and clear access to the Internet and it still wouldn't fix it. I've replaced a library in the Extension Manager and manual installs still fail with an authentication error. I have a feeling that it's Adobe's authentication system itself that is at fault here. But no proof or other candidates to blame that I can think of.
                                                      Work is on-going. I am hopeful, because everything installs just fine on my system at home with my own personal account.
                                                      BTW, I'm using a new Mac Pro, OS X 10.9.4. Working in an Active Directory environment.
                                                      What I don't understand is why extensions have to be authenticated to begin with? My Adobe software has to be activated already! Mind you I've done enough software development to know there's likely a very good answer to that question. But for the heck of it, I'm asking anyway!
                                                      • 24. Re: ERROR 604 KEEPS POPPING UP
                                                        I replied you from e-mail. Thank you for your information.
                                                        • 25. Re: ERROR 604 KEEPS POPPING UP
                                                          Are you using OSX or Windows?
                                                          • 26. Re: ERROR 604 KEEPS POPPING UP
                                                            Wahoo McDaniels Community Member
                                                            I dunno about Mad, but I'm on OS X v10.9.4.
                                                            • 27. Re: ERROR 604 KEEPS POPPING UP
                                                              OS X 10.9.4.
                                                              • 28. Re: ERROR 604 KEEPS POPPING UP
        Hi BladWor,
        You could download and install the product using the ZXP package by following these instructions (https://forums.adobe.com/thread/1504330).
        If it is not help, would you please collect log to us?
        Mac: /Users/<name>/Library/Application Support/Adobe/Extension Manager CC/Log/
        Windows: C:\Users\<name>\AppData\Roaming\Adobe\Extension Manager CC\Log
        2. Restart Extension Manager and reproduce your issue
        3. Send us ExManCoreLibrary.log file in that log folder to exman.beijing@gmail.com
        • 29. Re: ERROR 604 KEEPS POPPING UP
        Hey shuo_yang, I actually already tried that method, and I get basically the same error message, which says that "This extension cannot be installed because licensing verification failed. The extension with not be installed."
        Also, I tried to collect a log for you, but it didn't seem to work. I made a file in TextEdit, renamed it to exmancoreliblog.yes, and put it in the correct folder (though I had to also create a Log folder). No I can't find the ExManCoreLibrary.log you asked for. Where would that be?
        • 30. Re: ERROR 604 KEEPS POPPING UP
        Hi Wahoo,
        Some other customer sent the log file to us, and we found the root cause is that there is some firewall rule on your network, so you can not access Adobe license check server. If it is possible, please turn off your firewall, and change another network to continue.
        • 31. Re: ERROR 604 KEEPS POPPING UP
        pfalzgraff Community Member
        So let´s summarize: You´ve learned by help of your customers that your Software behaves in a way that firewalls for safety reasons does rule out in several cases. And instead of fixing this issue you´re asking to bring down a companies firewall?
