2 Replies Latest reply: Jul 18, 2014 7:26 AM by Aquitaine RSS
    CF11 - SQL Type Not Supported By This Driver on basic ORM Update
    Aquitaine Community Member
      We are testing out one of our web applications in CF11.
      We have a basic ORM entity update function that fetches an object, individually calls several setters, and then saves the entity inside a transaction tag in cfscript. We are working with Microsoft SQL 2012 Standard edition. This worked under CF9 and CF10.
      Under CF11, we get the following error:
      Error: An exception occurred when committing the transaction. The root cause of this exception was: coldfusion.orm.hibernate.HibernateSessionException: [macromedia][SQLServer JDBC Driver]The specified SQL type is not supported by this driver..
      The line of code throwing the error is whatever the last line inside the transaction {} block is.
      The SQL being run follows. This is super basic. What is going on here?
      Hibernate log:
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE DEBUG - update dbo.registrations set childID=?, registered=?, dropped=?, droppedBy=?, droppedDate=?, neverPlayed=?, WL=?, WLRemoveDate=?, WLRemoveBy=?, sexdiv=?, age_calc=?, Scholarship=?, VIP=?, PlayerSchool=?, Grade=?, PlayerHeight=?, PlayerWeight=?, PlayerEmail=?, PlayerCellPhone=?, LBrother=?, RecentlyMoved=?, submitterID=?, submitType=?, comments=?, RegistrationComments=?, CommentsDivDir=?, DroppedComments=?, RegistrarOnly=?, MedicalInsCarrier=?, MedCond=?, Mediprobs=?, PhysicianName=?, DoctorFull=?, EmergencyContact=?, EmergencyPhone=?, seasonID=?, moveUp=?, moveUpStatus=?, moveUpAsked=?, MoveUpOldDiv=?, PlayedLastYear=?, MethodOfPayment=?, Fee=?, RefundAmount=?, RefundDate=?, AmountPaid=?, InvoiceNo=?, Div=?, batchNum=?, sexdivNextYear=?, email_other=?, dateCreated=?, dateModified=?, lastModifiedBy=?, playerNum=?, refund=?, refundBy=?, donation=?, isAYSOExtra=?, yearbooksGiven=?, yearbooksOrdered=?, noPracticeDay=?, coed=?, clientID=?, seasonUID=? where registrationID=?
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [1] as [VARCHAR] - 37F22B1B-066D-45CB-BBDA-677D8059159D
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [2] as [BOOLEAN] - true
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [3] as [BOOLEAN] - false
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [4] as [VARCHAR] - <null>
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [5] as [TIMESTAMP] - <null>
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [6] as [BOOLEAN] - false
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [7] as [BOOLEAN] - false
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [8] as [TIMESTAMP] - <null>
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [9] as [VARCHAR] - <null>
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [10] as [VARCHAR] - B19
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [11] as [INTEGER] - 6
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [12] as [BOOLEAN] - false
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [13] as [BOOLEAN] - false
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [14] as [VARCHAR] - Test
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [15] as [VARCHAR] - 3
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [16] as [VARCHAR] - 23
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [17] as [VARCHAR] - 44
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [18] as [VARCHAR] -
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [19] as [VARCHAR] -
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [20] as [VARCHAR] -
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [21] as [BOOLEAN] - false
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [22] as [VARCHAR] - 75F5114C-B32A-4BDA-A125-93FAB7EB3834
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [23] as [VARCHAR] - Father
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [24] as [VARCHAR] - test
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [25] as [VARCHAR] - test
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [26] as [VARCHAR] - <null>
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [27] as [VARCHAR] - <null>
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [28] as [VARCHAR] - test
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [29] as [VARCHAR] - BCS
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [30] as [BOOLEAN] - false
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [31] as [VARCHAR] -
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [32] as [VARCHAR] -
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [33] as [VARCHAR] -
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [34] as [VARCHAR] - LK
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [35] as [VARCHAR] - 302-555-1212
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [36] as [INTEGER] - 9
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [37] as [SMALLINT] - 1
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [38] as [INTEGER] - 0
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [39] as [BOOLEAN] - false
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [40] as [VARCHAR] - <null>
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [41] as [BOOLEAN] - <null>
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [42] as [VARCHAR] - Credit Card - Automated
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [43] as [DOUBLE] - 100.0
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [44] as [DOUBLE] - <null>
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [45] as [TIMESTAMP] - <null>
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [46] as [DOUBLE] - <null>
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [47] as [VARCHAR] - 7176
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [48] as [SMALLINT] - 8
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [49] as [VARCHAR] - <null>
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [50] as [VARCHAR] - B8
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [51] as [VARCHAR] -
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [52] as [TIMESTAMP] - 2013-07-19 12:29:50.0
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [53] as [TIMESTAMP] - {ts '2014-05-07 19:21:04'}
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [54] as [VARCHAR] - 75F5114C-B32A-4BDA-A125-93FAB7EB3834
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [55] as [INTEGER] - 18973
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [56] as [BOOLEAN] - false
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [57] as [VARCHAR] - <null>
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [58] as [DOUBLE] - <null>
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [59] as [BOOLEAN] - false
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [60] as [SMALLINT] - 0
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [61] as [SMALLINT] - 0
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [62] as [VARCHAR] - Wednesday
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [63] as [BOOLEAN] - false
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [64] as [VARCHAR] - 2BDE1C40-A442-46D0-AD11-2E9E9F078069
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [65] as [VARCHAR] - 8FD74B93-990E-4DFE-8D0A-352EA5461180
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE TRACE - binding parameter [66] as [VARCHAR] - 42E5F844-1310-41CE-BDD6-BB4E6FB8D847
      05/07 17:21:04 [ajp-bio-8014-exec-1] HIBERNATE ERROR - [macromedia][SQLServer JDBC Driver]The specified SQL type is not supported by this driver.
