1. Re: Skin change in the RH 5
Willam van Weelden Jul 17, 2014 2:17 AM (in response to robolearner)If you create CHM, there is not much to be done in the way of styling. It's a Microsoft technology and hasn't been updated in years. No way to change how it looks.
There are, of course, alternatives to CHM. Whether you can use them depends on what you are trying to achieve. You can manually create a WebHelp/CHM hybrid but it requires you to create a WebHelp output and then create a new project, adding every WebHelp output file as a baggage file. Huge time investment.
Another offline format is AirHelp, which was introduced with RH7 but it never really took off.
From your post, it seems you can neither upgrade to a newer version of RH or use online format. Is that correct?
Kind regards,
Willam
2. Re: Skin change in the RH 5
robolearner Jul 20, 2014 10:46 PM (in response to Willam van Weelden)Yes, from this version , there is no facility to upgrade to any latest
version. Also, this documentation has to be delivered along with the
application build, so irrespective of having access to the web the users
must be able to read this file.
Is there any other way to solve this issue?
Sent: Thursday, July 17, 2014 2:48 PM
To: Chatura Machavolu
Subject: Skin change in the RH 5
created by Willam van Weelden
<https://forums.adobe.com/people/WillamvanWeelden> in HTML Help (CHMs)
- View the full discussion
3. Re: Skin change in the RH 5
Willam van Weelden Jul 23, 2014 2:12 AM (in response to robolearner)You can update your content styling, but that's about as far as you can. The only other way is to (have a developer) create a tool to mimic the WebHelp in CHM script for you. Otherwise you are constraint by the CHM technology.
Kind regards,
Willam
