CFForm format="flash" result a blank page
Aug 14, 2007 Aug 14, 2007
Hey guys,
I have search the net for most of the day to find a solution but came up with nothing. I am trying to use flash form to give my app a better look. When I use format="flash" with my cfform tag, the form does not render, but if I use xml or html format it works fine. I have checked and double check all the spellings and made sure all tags close but nothing seem to work. I have also checked the mapping for cfide and it points to the right place. I can't figure out what is wrong. I even have the latest version of flash player installed.
Here is what I have.
Server: CFMX 7 DevNet edition
on MAC OS X, running on top of built in apache.
Browser: FireFox 2.0.0.6, and Safari 2.0.4
Thanks for your help.
Jay
Advanced techniques
521
Aug 15, 2007 Aug 15, 2007
Make sure you have a virtual directory on your web server for CFIDE.
I think I do, here is what I see in my cfAdmin - mapping section
/CFIDE /Library/WebServer/Documents/CFIDE
If this is not what you are taking about, I don't know what your asking me to do. perhaps an example or a pointer would be great.
Thanks.
I think this has to actually be a web server mapping, not a CF mapping. The reason for this is that the flash forms use javascript that is in one of the directories under the CFIDE directory. So, in a <script src=""> tag, the web server has no idea what a CF Mapping is.
The files that the flash forms are looking for are:
/CFIDE/scripts/cfform.js
/CFIDE/scripts/masks.js
/CFIDE/scripts/cfformhistory.js
/CFIDE/scripts/cfformhistory.cfm
Alternatively you could copy these files to another directory under your webroot and use the scriptSrc attribute of the CFFORM tag.
Hey ssawka,
So did as you asked. I have created a virtual directory in apache for CFIDE and cfide (with out the latter cfadmin caused problems.). But I still get a blank page. I even copied the scripts folder into my local web root, where I have other js scripts and used scriptSrc attribute to point to the directory, that didn't work either. When I look at the html source code, its looking for two javascripts cfform.js and marks.js and is looking for both of them in the right place. But I still can't figure out why I can't see my flash form.
I had the same problem. I wanted my app to look cool by using flash forms. I spent countless hours messing with it. I took the page and iteratively took things off until the page worked. What I ended up with is a page with no table tags or html on the page. Once I did that, the flash form worked fine. Unless I missed something, you can't have anything else besides the flash form itself on the page to make it render. Not practical at all!
I just tried that as well. Still doesn't work. How ever I did notice a meta tag added my CF, can it cause a problem? if so how do I remove it.
Here is what my html source code looks like.
Documentation
