quote:
Originally posted by: 5.0Montecarlo
Thanks for the response GEWB. Unfortunately, I don't believe this is the answer since most of the popups work fine. It's only the most recent ones that aren't functioning properly. I've tried changing a few settings under Internet Options, namely "Allow Active Content to run in files on My Computer." This eliminates the error message and a window does popup when I select the link, but the window is blank with the image missing. Any other ideas?
quote:
Originally posted by: HKabaker
You'd think that old files would stop working when new ones don't work.
Is something different between the new and old htm files? Did you use the same procedures for inserting links, creating popups, inserting images, storing targets within the same file structure? Did you start using PNG images rather than jpeg and gif? Do the new files try to reach out for targets in an external environment? Double-check hyperlinks for correct paths to targets?
Harvey
Are you attempting to pop up the image alone?
Or are you creating a new topic, inserting just the image, and linking to it as a popup from the parent topic?
Another issue is the bmp file type. Some time ago I tried using a bmp but couldn't import it into the topic because the RH insert image dialog didn't show it -- gif and jpg were the best choices. I haven't tried bmps lately.
H
Linux Rules that did the trick. Thanks a lot for the help. Any thoughts as to why this might have started happening?
Gary
