In existing Table:
How can I make first two rows as a Heading Rows, so it can be repeated on every page???
Could not find this option on Table Designer or Paragraph Designer.
Thanks.
Even easier, when the table is selected, use Table > Add Rows or Columns... and then specify the number of heading rows required:
Then just cut & paste the rows into the new heading rows.
Click in current Heading row.
<*> Add [ 1 ] Row(s): Above Selection
[ Add ]
Restoring a heading row to a table without one is another matter.
Thanks Error7103,
The existing table has no Heading Row.
So will I be able to create or assign new Heading Rows for the existing table???
Thanks.
Create a new empty table of the named format, with the desired number of various rows and columns.
Save the file.
Select and cut* the content out of the old table.
Paste it into body row 1 of the new one.
Delete old table.
Add text to new heading row(s).
Or learn to hack tables in MIF.
Yup. This is a shortcoming of FM's table support.
______
* Copy is OK as long as there are no Markers in the table.
Too easy. I never noticed that option before. And it's been in the product for a long time.
Thank you all,
I agree with Error7103, Arnis' answer was too easy as it shows.
I also thank Error7103, your earlier response was also very good, more like common sense. Appreciate it.
PS: I have one question in your comment:
What is the Hacking MIF, and where can I find more info related to it???
Save file as MIF to .mif
Hack with plaintext editor.
See also:
MIF Reference manuals for FM11 & 12 available
This is obviously not necessary for your situation, but MIF mucking for tables is sometimes done. We use it to convert arbitrary (pasted-in) spreadsheet data to a fully formatted FM table with useful cross-reference markers already in place. Paste in the data in one sheet. Copy out the raw MIF from another. Open in FM and copy to final document. The spreadsheet was originally created by deconstructing a formatted table in MIF.
