1 Reply Latest reply: Jul 22, 2014 1:25 PM by Carl Von Stetten RSS
    If statement in update query
    TheScarecrow Community Member
      I was wondering if you could have a cfif statement inside of a update query.  See example below.  Is there a better way of doing it? thanks.
      <cfquery DATASOURCE="xxx" name="update">
        UPDATE plant_gen_info
              SET levels_complete = #URL.var0#
                  <cfif IsDefined("URLvar13">
                  ,Q1_answer = #URL.var13#
                  </cfif>
              WHERE ID = #session.member_id#
        </cfquery>
        • 1. Re: If statement in update query
          Carl Von Stetten MeganK
          TheScarecrow,
          Yes, dynamic query statements can be assembled using <cfif>.  I would suggest you switch your IsDefined() to a StructKeyExists() and strongly suggest you make good use of <cfqueryparam>:
                  SET levels_complete = <cfqueryparam value="#URL.var0#" cfsqltype="****">
                      <cfif StructKeyExists(URL, "var13")>
                      ,Q1_answer = <cfqueryparam value="#URL.var13#" cfsqltype="****">
                      </cfif>
                  WHERE ID = <cfqueryparam value="#session.member_id#" cfsqltype="****">
            </cfquery>
          I put a "****" placeholder for cfsqltype attributes because I'm not sure which would be appropriate for your variables.  See the help docs for more on the cfqueryparam and cfsqltype.
          -Carl V.
